Convert brat manual steering to power steering
  On 4/2/2013 at 9:06 PM, jj421 said:
I'm no expert, but you'll need the power steering rack, P/S pump, P/S pulley, all the P/S lines, and a longer belt. Not sure if there's anything else.
Everything bolts on.  Strip all the parts from a donor vehicle and install to yours.  There's also a smaller universal joint that connects the rack to the steering column plus a different thermostat housing that's longer to clear the P/S pump.  As well as the P/S pulley you'll need to have the triple pulley for the crankshaft which will also involve (I believe) getting rid of the crank fan if you still have it and installing a slimline electric fan instead (I could be wrong on that point).
