no low beams
there should be two headlight realys right above your left knee under the plastic cover wiring should be black with red stripe or black yellow black and white. But as far as i know realys are left and right not high low so u whould only lose one side not all four bad contacts in high low switch mabee
Glad to hear you found the problem. The headlights do share a commom relay like Ivans Imports thought. The power for the dash lights is also passed though one of the relays. The grounding for the selected lights is made through the light switch.
