1-3-2-4 Posted April 7, 2013 Share Posted April 7, 2013 How much does the long block weigh in at?I want to guess 265-290? Link to comment Share on other sites More sharing options...
4play Posted April 7, 2013 Share Posted April 7, 2013 (edited) I dont know for shure but I do know to guys can lift a compleat moter in to the back of a truck, Edited April 7, 2013 by 4play Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 7, 2013 Author Share Posted April 7, 2013 I know I can lift the 5 MT by myself and that's equal weight with me.. I might be able to move a Ej22 by myself for a short distance, Not sure about the Ej22 heads but the EJ25 heads are pretty damn heavy alone. Link to comment Share on other sites More sharing options...
86BRATMAN Posted April 7, 2013 Share Posted April 7, 2013 I've moved one, uncomfortably I add, couldn't do it alone anymore because of my back. I'd say it's st least 200 dry. Link to comment Share on other sites More sharing options...
987687 Posted April 7, 2013 Share Posted April 7, 2013 (edited) EJ22 heads aren't that heavy, maybe 30lbs each, or thereabouts. Today I lifted an ej22 longblock without accessories into the back of my outback without completely killing myself, and I'm not really a big guy. It can't be much over 200, if even that much. Edited April 7, 2013 by 987687 Link to comment Share on other sites More sharing options...
fishy Posted April 7, 2013 Share Posted April 7, 2013 Would it be about the same as a 25? I weighed an ej25 longblock with nothing bolted on but the flywheel and it was about 140lbs. The heads (not on for the longblock weight) were about 25lbs each. Link to comment Share on other sites More sharing options...
fishy Posted April 7, 2013 Share Posted April 7, 2013 On 4/7/2013 at 10:43 AM, fishy said: Would it be about the same as a 25? I weighed an ej25 longblock with nothing bolted on but the flywheel and it was about 140lbs. The heads (not on for the longblock weight) were about 25lbs each. Now that I think about it that motor had the oil pan and some oil too... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 7, 2013 Share Posted April 7, 2013 Maybe Ivan will chime in, or PM him. At one time he was very concerned with engine weight, trying to lighten an engine in a hovercraft. Link to comment Share on other sites More sharing options...
Gloyale Posted April 7, 2013 Share Posted April 7, 2013 Aircraft guy in my area says a 2.2 longblock, dry, weighs 262. Link to comment Share on other sites More sharing options...
Subaru_dude Posted April 8, 2013 Share Posted April 8, 2013 At one time I was deadlifting 465, and that summer I also pulled an EJ22 out of a junkyard car with help. When I got back to my house, I moved it out of the back of the EA82 turbo wagon I was driving at the time and walked maybe 30ft to a tire to sit it in. It's hard to judge weight because when deadlifting you're keeping the weight close to you, but when lifting something like an engine it's impossible to compare. The only problem is, it's just very awkward. I would say it was nearly as "difficult" as lifting my max deadlift weight, just becasue there's no real places to hold onto it. 262 sounds about right. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 8, 2013 Author Share Posted April 8, 2013 On 4/8/2013 at 1:56 AM, Subaru_dude said: At one time I was deadlifting 465, and that summer I also pulled an EJ22 out of a junkyard car with help. When I got back to my house, I moved it out of the back of the EA82 turbo wagon I was driving at the time and walked maybe 30ft to a tire to sit it in. It's hard to judge weight because when deadlifting you're keeping the weight close to you, but when lifting something like an engine it's impossible to compare. The only problem is, it's just very awkward. I would say it was nearly as "difficult" as lifting my max deadlift weight, just becasue there's no real places to hold onto it. 262 sounds about right. That's what people said about the 5MT I carried it down steps and moved it around with no problem at all. Why not pick the motor up under the heads. Link to comment Share on other sites More sharing options...
