Subie57 Posted April 10, 2013 Share Posted April 10, 2013 ok i have searched and searched for wheel options for my 95 impreza coupe with the soon added forester KYB GR2 struts King Springs and SJR 4in lift. i willbe running 225/75/16s or 15s. butneed to find a off set around 30mm or so. but i cant find anything.. thanks john. Link to comment Share on other sites More sharing options...
Numbchux Posted April 10, 2013 Share Posted April 10, 2013 Not going to find much. Most vehicles that run 5x100 run higher than that. But, some 10-15mm spacers should get you right in the ballpark. Link to comment Share on other sites More sharing options...
Subie57 Posted April 10, 2013 Author Share Posted April 10, 2013 Spacers require longer studs which is fine just a pain in the rump roast to do on subarus. Pull the spindles press the hub out knock out all the studs. I was tryin to stay away from that but guess I can't Link to comment Share on other sites More sharing options...
Numbchux Posted April 10, 2013 Share Posted April 10, 2013 Spacers require longer studs which is fine just a pain in the rump roast to do on subarus. Pull the spindles press the hub out knock out all the studs. I was tryin to stay away from that but guess I can'tIt can be done without pulling the hub. I've done stock length studs many times, I bet longer ones would work. Maybe not the crazy long ARP studs... Look into the H&R spacers, I'm running a pair of 15mm ones on the back of my Celica. They came with studs that are the perfect size, and they're very nice hub-centric spacers. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted April 10, 2013 Share Posted April 10, 2013 I ran some aftermarket rims , same ones on Trons car, they had a little more offset Link to comment Share on other sites More sharing options...
