BlueSoob Posted April 20, 2013 Share Posted April 20, 2013 93 legacy automatic.. been sitting dead for awhile. went to jump start it.. now the key won't come out of the ignition... i know there is a trick to this.... but I can't remember what..... amanda Link to comment Share on other sites More sharing options...
mikaleda Posted April 21, 2013 Share Posted April 21, 2013 It's in park right? If its not in park the key wont shut off all the way, so it will get stuck. Link to comment Share on other sites More sharing options...
BlueSoob Posted April 21, 2013 Author Share Posted April 21, 2013 yep in park. even tried it in neutral... the key won't turn back to the off position Link to comment Share on other sites More sharing options...
mikaleda Posted April 21, 2013 Share Posted April 21, 2013 A couple other things to try are stepping on the brake, wiggle the steering wheel back and forth as your trying to turn the key off, try switching from drive to park a few times in a row, and try turning the car back on and off again and maybe it will come out. If none of that works I would suspect the sylinoid that locks the key in when not in park is malfunctioning. Link to comment Share on other sites More sharing options...
Pooparu Posted April 21, 2013 Share Posted April 21, 2013 Try hitting the key with a hammer to push it into the ignition more. Link to comment Share on other sites More sharing options...
mikaleda Posted April 21, 2013 Share Posted April 21, 2013 On 4/21/2013 at 3:49 PM, Pooparu said: Try hitting the key with a hammer to push it into the ignition more. Really? I would save that for a last resort, if the key isn't turning off it suggests something's binding it up or it's being locked out for some reason. Hitting it with a hammer could case the tumblers to break if they are binding. Link to comment Share on other sites More sharing options...
Pooparu Posted April 23, 2013 Share Posted April 23, 2013 On 4/21/2013 at 4:22 PM, mikaleda said: Really? I would save that for a last resort, if the key isn't turning off it suggests something's binding it up or it's being locked out for some reason. Hitting it with a hammer could case the tumblers to break if they are binding. It worked for me. Link to comment Share on other sites More sharing options...
mikaleda Posted April 24, 2013 Share Posted April 24, 2013 Just because it works doesn't mean it's right, like I said I would leave it for a last resort. Link to comment Share on other sites More sharing options...
