used car Posted April 21, 2013 Share Posted April 21, 2013 Have 1987 subaru gl 1.8 4-wheel drive. Grinding clunking sound from right front end area when accelerating and turning right.It quits when i let off on gas.... What could it be?...Need your help! Quote Link to comment Share on other sites More sharing options...
Reza Posted April 21, 2013 Share Posted April 21, 2013 check wheel bearings and inspect the cv. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted April 21, 2013 Share Posted April 21, 2013 (edited) check wheel bearings and inspect the cv. +1 make sure to jack the front tires up off the ground when inspecting. Edited April 21, 2013 by mikaleda Quote Link to comment Share on other sites More sharing options...
NorthWet Posted April 21, 2013 Share Posted April 21, 2013 Any front end work in the last couple months? Quote Link to comment Share on other sites More sharing options...
Zekeuyasha Posted April 21, 2013 Share Posted April 21, 2013 wiggle the brake disks and check for any play in the ball joints Quote Link to comment Share on other sites More sharing options...
ford'ssubaru's Posted April 22, 2013 Share Posted April 22, 2013 Jack up the front of the car. Remove wheel covers. Grab hold of tire and shake sternly. Take pry bar and pry up and down on tire listen for clunking. Inspect axle nut where attached to hub for signs of spinning. Very common to have splines strip. Inspect CV boot carefully if it has thrown the grease out it probably is bad. If the boot is nice and clean though most likely the wheel bearing like posted above. If you have the time and money do both sides. 1 Quote Link to comment Share on other sites More sharing options...
used car Posted April 24, 2013 Author Share Posted April 24, 2013 Any front end work in the last couple months? Yes had right cv axle replaced,ball joint,and cone and spring washers.Still has wheel noise. Quote Link to comment Share on other sites More sharing options...
