teampnw Posted April 25, 2013 Share Posted April 25, 2013 Hey guys, Does anyone have a good resource on clutch replacement. mine went out yesterday and im looking for some good info. much appreciated! Link to comment Share on other sites More sharing options...
SLCPUD Posted April 25, 2013 Share Posted April 25, 2013 I rebuilt my engine and clutch about two years. I went online to Ebay and purchased a clutch kit to include pressure plate, clutch disc, release bearing, pilot bearing, and alignment tool for about $75 which included shipping. Link to comment Share on other sites More sharing options...
man on the moon Posted April 26, 2013 Share Posted April 26, 2013 ShawnW should be able to hook you up, and part of the money goes to support this board. He owns a Subaru shop and can get good prices and the right part for you . Send him a PM. 1 Link to comment Share on other sites More sharing options...
Turbone Posted April 29, 2013 Share Posted April 29, 2013 Hey guys, Does anyone have a good resource on clutch replacement. mine went out yesterday and im looking for some good info. much appreciated! Please, lets follow the KISS principal here. The OP was only looking for resources for a clutch replacement, not engine rebuilds etc. 1 Link to comment Share on other sites More sharing options...
teampnw Posted April 29, 2013 Author Share Posted April 29, 2013 (edited) Yes im looking for like some pictures or information on the smoothest way to do the procedure Right now i am preparing to unbolt the transmission. any ideas on the best way to handle this? Also do you have to replace the transmission gasket after? Thanks for the help! Edited April 29, 2013 by teampnw Link to comment Share on other sites More sharing options...
MilesFox Posted April 29, 2013 Share Posted April 29, 2013 watch. the. videos. http://www.ultimatesubaru.org/forum/topic/135970-the-art-of-subaru-maintenance-video-series-ea82/ The videos detail removing the engine first(if you want to reseal it) and swapping an automatic to a 5spd (which illustrates the clutch installation) Link to comment Share on other sites More sharing options...
Crazyeights Posted April 30, 2013 Share Posted April 30, 2013 Please, lets follow the KISS principal here. The OP was only looking for resources for a clutch replacement, not engine rebuilds etc. Sorry if I started the thread off on a wrong turn. I was just stating what works easier for me. 1 Link to comment Share on other sites More sharing options...
teampnw Posted April 30, 2013 Author Share Posted April 30, 2013 watch. the. videos. http://www.ultimatesubaru.org/forum/topic/135970-the-art-of-subaru-maintenance-video-series-ea82/ The videos detail removing the engine first(if you want to reseal it) and swapping an automatic to a 5spd (which illustrates the clutch installation) Thanks this really helps! Im having trouble removing the transaxle... whats the best way to proceed? Link to comment Share on other sites More sharing options...
AKghandi Posted April 30, 2013 Share Posted April 30, 2013 if you are just doing a clutch,pull the radiator, undo the motor mounts, the heater core lines,the y pipe, the starter, and the engine to case bolts. jack up and slide the engine forward till you can get at the clutch. it might be hard to get a clutch alignment tool in there so just leave the pressure plate bolts loose and tighten them through the starter hole once its back together. its going to take some creative jack work and motor wiggling but it will go back together, its helpful to jack the trans up also. so they can go back together without jamming on the motor mounts,you could also remove the motor mounts and re install them once the engine and trans is back together. I've done a couple like this, mostly on beateroos and it takes about 4 hrs if you know what your doing. Link to comment Share on other sites More sharing options...
MilesFox Posted May 1, 2013 Share Posted May 1, 2013 I would vote for pulling the engine, but to pull the trans, remove the shifter, drop the carrier bearing and the driveshaft, and unplug all the electrical connections to the trans. Then you will want to drop the exhaust header pipe. Now you can remove the roll pins on the axles with a 3/16 drift punch. revove one of the ball oints or control arm link to allow room to slide the axles from the trans, you should have wiggle room to do the other side. From here you can undo the bolts to the trans crossmember and lower it down. Leave the crossmember bolted to the the trans. remember to make sure the roll pin holes line up the correct way when reinstalling. The trans may be hard to find the pilot hole and thus much frustrating wiggling. On the motor side, you may have to reinstall the pitch bar or put a block of wood in front of the negine to angle it back to install the trans. I would only recommend pulling the trans if you have a lift. Now you can see where pulling the engine is more efficient. You still have the same bell housing bolts, but you dont have to separate the exhaust at the donut gaskets, pull ball joints and axles, and tear the console apart to get at the shifter. Just the same 4 bolts and then the 2 engine studs, fuel hoses, coolant hoses, a few electrical plugs, and you have access to the whole motor if you feel like doing water pumps and cam seals, which you may as well do since the motor will sit in a milk crate of 5 gallon bucket Link to comment Share on other sites More sharing options...
Gloyale Posted May 1, 2013 Share Posted May 1, 2013 You do NOT need to remove balljoints, control arm, or any front suspension to drop the trans out the bottom. Pop out the pins, prepare everything else, and then as the trans is pulled back and down slightly, you can push it to one side, slide off an axle, then push it to the other side. Reinstall is the reverse. Easier with 2 people and a good tranny jack. Tranny jack is cheaper, and smaller to store than an engine hoist. I really do not understand the "easier to pull the engine" philosophy of clutch replacement. Unless there is a good reason to pull the engine, leave it in place and save yourself the coolant, and fuel line removal. 2 Link to comment Share on other sites More sharing options...
man on the moon Posted May 7, 2013 Share Posted May 7, 2013 You don't have to pull the motor, just lift it about two inches and slide it forward about eight inches. You have the same amount of workspace that is accessible from the top. It can all be done standing up. I can do this alone, even at my whopping 110 pounds! I've also done a tranny swap, which wasn't too bad, but for just a clutch I would vote for just sliding the motor forward. Dropping the trans requires working laying on your back the entire time, including any lifting or shifting of the trans... It can be done both ways, so decide which is easier for you. Leaving hoses and wiring in place on the motor sounds good? Drop the trans. Doing the whole kit-and-kaboodle without laying on your back or having to put the car up on jack-stands? Slide the motor forward. It's apples and oranges, not life-or-death. As for alignment tools, grab a sparkplug from the motor. Any of the sparkplugs in your motor will work. Insulation goes in, spark point out. Ceramic bit fits in the pilot bearing hole, and the wrenchy-angly bit of the plug fits in the hole in the clutch plate. Line 'er up, snug down the pressure plate, put the plug back in the motor. Get everything put mated-up and put together. Final tighten through the starter hole (requires turning the motor by hand, use a 22mm wrench on the crankshaft pulley). Done. That's it. Link to comment Share on other sites More sharing options...
man on the moon Posted May 7, 2013 Share Posted May 7, 2013 Gloyale is correct in the stuff for trans drop. No need to mess with front suspension. Just drop the exhaust at the heads, drive shaft at its center-mount point, linkage, and roll pins. Undo the four bellhousing bolts and wiring on the trans (very basic, and all connectors are unique from each other). Can be done solo, though I recommend someone be nearby in case things go south. Link to comment Share on other sites More sharing options...
MilesFox Posted May 7, 2013 Share Posted May 7, 2013 (edited) Gloyale is correct in the stuff for trans drop. No need to mess with front suspension. Just drop the exhaust at the heads, drive shaft at its center-mount point, linkage, and roll pins. Undo the four bellhousing bolts and wiring on the trans (very basic, and all connectors are unique from each other). Can be done solo, though I recommend someone be nearby in case things go south. Depends on your method and experience. I have don these either way. The last trans swap i did i had disconnected the suspension because i was swapping struts anyway. You can remove the trans without removing the suspension as you can get some wiggle room my mofing the trans back and forth, but this is easiest with the engine out (if you were removing the trans.) And yes, you can just move the engine forward enough to get at the clutch without disconnecting a lot of hoses, cables, or harnesses. I would only recommend this if you were already familiar with pulling soob engines so you know what to predict, and this requires a crane out of any of these options, pulling the motor is easiest, provided that space and access to an engine crane is not difficult. Vs just sliding the engine forward, it is only a few more steps to yank the engine if you wanted to put it on a stand and do all of the seals. Well worth it if you are considering the oil pan gasket. Do the cam tower o-rings if you are ambitious Edited May 7, 2013 by MilesFox Link to comment Share on other sites More sharing options...
Gloyale Posted May 7, 2013 Share Posted May 7, 2013 Any engine pulling or sliding forward requires removing more bolts, and draining the coolant. Not to mention powersteering and AC belts and pumps, And fuel lines for removing engine. I just can't justify wasting coolant and R+R'ing more bolts/parts. I guess a good tranny jack and a creeper make the world of difference. Link to comment Share on other sites More sharing options...
teampnw Posted May 7, 2013 Author Share Posted May 7, 2013 Thanks for all the input! I ended up dropping the transmission and putting it on a dolly and sliding it out and replacing the clutch. Almost done putting everything back into place. Link to comment Share on other sites More sharing options...
MilesFox Posted May 7, 2013 Share Posted May 7, 2013 Easier done than said 2 Link to comment Share on other sites More sharing options...
Rust Posted May 9, 2013 Share Posted May 9, 2013 I have done clutch jobs w/o removing the y-pipe, or any engine mounts. Just bolted up a fabbed up metal plate to the skid plate and slide the tranny back on it. Its a lot eaisier to pitch the engine forward, but, It can be a nightmare trying to re-install your y-pipe here in the rust belt. Doing a helicoil, re-tapping threads, ect can be more work and frustration than bolting up a new disc/pressure plate. Link to comment Share on other sites More sharing options...
Subaru_dude Posted May 9, 2013 Share Posted May 9, 2013 I don't know if it's an issue with EA cars, but on EJs you run the risk of snapping the capture nuts for the tranny crossmember loose if you drop the trans. Has happened to me on BOTH EJ cars I've dropped transmissions on. Never again. But like I said, that might not be an issue on EA cars. Link to comment Share on other sites More sharing options...
