Lacyjs9 Posted April 29, 2013 Share Posted April 29, 2013 i smell gas when i get off the interstate and only when i get off the interstate any advice im getting like 16 mpg and i cant figure it out ive adjusted the timing replaced both fuel filters and all the vacuum hoses&plugs and wires Link to comment Share on other sites More sharing options...
moosens Posted April 30, 2013 Share Posted April 30, 2013 Take the air cleaner housing off and inspect the tiny rubber boot on the accelerator pump which sits atop your carburetor. Right up front. Has a lever attached with a pin retainer. Could be something else but that is a current problem for a couple of us with old carbs. Link to comment Share on other sites More sharing options...
bendecker Posted April 30, 2013 Share Posted April 30, 2013 While you are at it, look for a leaky butterfly valve. That's where mine recently started to stink. Gas was dribbling out the side of the carb through the worn-out bushing. Link to comment Share on other sites More sharing options...
moosens Posted May 1, 2013 Share Posted May 1, 2013 Right , thanks Ben. The metal fatigue issue ...... grrrrr. But only coming off the highway ....hmmmm Link to comment Share on other sites More sharing options...
spazomatic Posted May 1, 2013 Share Posted May 1, 2013 Does it start to act up as well? Or just the smell of fuel? Link to comment Share on other sites More sharing options...
Lacyjs9 Posted May 1, 2013 Author Share Posted May 1, 2013 On 5/1/2013 at 1:19 PM, spazomatic said: Does it start to act up as well? Or just the smell of fuel? some times its misses and sputters and today i noticed wen i was fueling up when i took off the gas cap there was no pressure it didnt hiss like t normally does Link to comment Share on other sites More sharing options...
