idosubaru Posted April 29, 2013 Share Posted April 29, 2013 1999 EJ22. apparently the exhaust and intake valve springs have painted marks indicating top and bottom. but nothing looked different so i assumed it didn't matter when assembling. i don't even think the paint was visible on them all or I would have noticed. i already assembled the heads, does it matter? Link to comment Share on other sites More sharing options...
idosubaru Posted April 29, 2013 Author Share Posted April 29, 2013 here's a thread with a picture detailing the difference if you can't see the painted marks any more. http://forums.nasioc.com/forums/showthread.php?t=2042002 part of me thinks this won't matter...part of me thinks otherise. if i pull them again i need a different valve spring compressor - i've tried two. one doesn't work and the other took hours and was nearly impossible to use, always cranked at odd angles and always interfering with some part of the head. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 29, 2013 Share Posted April 29, 2013 The springs are progressive rate and that could affect wear on the seat of the spring. But mostly this will affect the amount of weight that has to rebound when the valve closes. You could run into some valve float issues at higher rpm. I've found the t-bar type compressors to work well on these if you have a bench that you can clamp the head to hold it down. Otherwise you need the c-clamp style with the smallest retainer adapter you can get. Link to comment Share on other sites More sharing options...
idosubaru Posted April 29, 2013 Author Share Posted April 29, 2013 t-bar type works good on the Phase II EJ's? heads are bolted to engine on engine stand - chances of doing this with heads insitu? Link to comment Share on other sites More sharing options...
CNY_Dave Posted April 29, 2013 Share Posted April 29, 2013 t-bar type works good on the Phase II EJ's? heads are bolted to engine on engine stand - chances of doing this with heads insitu? Commonly done to replace valve seals by threading an air line into the spark plug hole and pressurizing the cylinder, the pressure holds the valves in place, even if they are vertical.. Never saw the adapter for this for sale, but they're out there. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 29, 2013 Share Posted April 29, 2013 Use a rope instead of air. Feed the rope in about 2-3 feet of it then turn the engine to TDC for that cylinder. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted April 30, 2013 Author Share Posted April 30, 2013 experienced NASIOC guy said it'll be fine for daily driving and for any high rev applications will want to correct them. that makes sense. goal is to find a valve spring compressor that is simple and effective though, i'll plug around online tomorrow. thanks guys. Link to comment Share on other sites More sharing options...
idosubaru Posted April 30, 2013 Author Share Posted April 30, 2013 surprised how few replies i got, i know someone has done this before! Link to comment Share on other sites More sharing options...
