Trailer wiring for 95 Legacy Outback
I recently got a hitch for my wagon and am wanting to go with a plug-n-play solution to adding trailer lights. Do they pretty much plug in to one of the tail lights and split off from there to the trailer?  Anybody have one they can recommend?
Thanks.
The later outbacks have a plug tucked in with the taillight harness that the tow lights plug into. Legacys of the same year do not. The 95 outback was more of a legacy than the later 96+ Outbacks, so it may not have the plug either.
You do need a converter box to combine the separate turn signal and brake lights into one bulb for the trailer.
if equipped, the connector is tucked into the side/quarter panels in the trunk.
my 96 legacy sedan doesn't have the plug in connector and i suspect a 95 doesn't have one either, but easy enough to check.
it can't be exaggerated how easily and nonproblematic they are to install though if needed.
$23 shipped and i'll send you an extra that I have.
