I did do a search with no luck.  Wanted to see if anyone has installed a license plate backup camera in a Subaru Baja?  I have one and am really curious what would be the best way to route the wires and where to get the power from.  Let me know if you have done this.  Thanks
Ken
Can you get under or in the side area of the bed?  If so I'd run the wiring in/along there so it's out of the weather, but if that's not possible put wiring loom around the wires and zip tie / mount the wiring so it can't be snagged by debris brushing on the underside of the car.  Also, make sure to use rubber grommets to seal the entrance/exit point in the cabin.
