soobscript Posted May 14, 2013 Share Posted May 14, 2013 In my years of research on here and working on these cars, I have in my head that EA82s have a VF-7 and EA81s have a VF-4 then early Leggys get a VF-11. If that is wrong we can end the discussion. It is also my understanding that the EA81T VF-4 was oil-cooled only. Well, I pulled the turbo from my 88 RX. The unit is clearly marked as VF-4, and it is water-cooled. I'm pretty sure that it is the same turbo that came in the RX with ~120k miles. The previous owner had it for a couple years and thought that it was an original motor. It could be from a different EA82, or maybe bonus junk from another car purchase, but I'm pretty sure it was my first one and daily driver. Could it be a rebuilt VF-7 with a VF-4 compressor housing (where the marking are)? One of my motors is one of the JDM imports, could it be a JDM-only legit water-cooled VF-4? Link to comment Share on other sites More sharing options...
86BRATMAN Posted May 14, 2013 Share Posted May 14, 2013 I remember reading that the ea81t's had either a tsb or recall to install a water cooled turbo. Its quite possible the replacement units were the same as early ea82 turbos Link to comment Share on other sites More sharing options...
scoobiedubie Posted May 14, 2013 Share Posted May 14, 2013 That turbo is an EA82 turbo and is both oil and water cooled. Link to comment Share on other sites More sharing options...
soobscript Posted May 14, 2013 Author Share Posted May 14, 2013 On 5/14/2013 at 5:41 PM, scoobiedubie said: That turbo is an EA82 turbo and is both oil and water cooled. So do EA82s normally get a VF-4? Link to comment Share on other sites More sharing options...
MilesFox Posted May 15, 2013 Share Posted May 15, 2013 IHI RHB5 from what i have seen Link to comment Share on other sites More sharing options...
soobscript Posted May 15, 2013 Author Share Posted May 15, 2013 There are dozens of different RHB5s. Quote RHB5 is a IHI frame size that was used in many turbos:The RHB52w is found in our Mx6/Probe's with the VJ11 from 89-91. AWarner Ishi RHB52w was also used in the TBird from 87-88 (VC32M -formanual trans and (VC32A) for auto) *(NOT a VJ17 which are from the non-U.S 323 GTX)*.Other RBH52w's include: 85-90 Isuzu I-Mark (VI-55), 84-87 IsuzuImpulse(Piazza)(VI-34), 90-94 Subaru Legacy (VF-11) and all 1.8L Tsubarus from 86-91. The VJ20 is in the 1.8L Mazda GTX the 88-98 1.6L 323had a VJ-14 and the 86-87 2.0L 626 had a VJ-5.The RHB52 was used in the 84-86 turbo Escorts(VC-31), the 88-89Chevy Spectrum (VI-55), 91-94 Ford Laser-Capri (VJ-14), 84-95 MercuryLynx (VC-31), Ferrari 208, and Bugatti EB110(x4). Fiat used them andit's a popular turbo for motorcycles. It was also going to be used in aTT version of the DeLorean, but the company supplying the parts went outof business before they could build them. The RHB51w is found in the 84-91 Maserati BiTurbo(VM-3 and VM-4) Some known RHB52 part numbers:subaru turbos:VF10 - RHB52XW - 5200 2 P15NR BRXLL4225CFZ 39.5mm/56mmVF11 - RHB52XW - 5200 2X P15NR BRLL4016EZ 37.5mm/52.5mmVF8 - RHB52XW - 10000 3X P20NR BRXLL4625CFZ 43.5mm/56mmVF12 - RHB52XW - 10000 3X P20NR BRXLL4726CFZ 45mm/56mm Isuzu turbos:VI34 - RHB52A-10000 3 P25NR BRL3911EZVI37 - RHB52W-10000 3 P25NR5 BRL3911EZVI23 - RHB52A-10000 3 P25NR BRL3911EZ and the mazda turbos:VJ11 - RHB52KW - 5200 2K P20NR5 BRL3911EZ 38mm/52.2mmVJ14 - RHB52MW - 5200 2M P12NR5 BRKL3711EZVJ16 - RHB52MW - 5200 2M P15NR5 BRKL3911EZVJ17 - RHB52BW - 10000 3B P25NR5 BRL4016EZVJ20 - RHB52UW - 5200 2U P15NR5 BRUL3911EZ 36.5/52.5mm Here's a TON more I found:www.turbomaster.info More RHB5 compressor/turbine dimensions:turbointernational.com ^^^ from http://www.angelfire.com/extreme4/mattmouth182_rag/mx6/page.html Link to comment Share on other sites More sharing options...
naru Posted May 15, 2013 Share Posted May 15, 2013 On 5/14/2013 at 5:03 PM, soobscript said: In my years of research on here and working on these cars, I have in my head that EA82s have a VF-7 and EA81s have a VF-4 then early Leggys get a VF-11. If that is wrong we can end the discussion. It is also my understanding that the EA81T VF-4 was oil-cooled only. Well, I pulled the turbo from my 88 RX. The unit is clearly marked as VF-4, and it is water-cooled. I'm pretty sure that it is the same turbo that came in the RX with ~120k miles. The previous owner had it for a couple years and thought that it was an original motor. It could be from a different EA82, or maybe bonus junk from another car purchase, but I'm pretty sure it was my first one and daily driver. Could it be a rebuilt VF-7 with a VF-4 compressor housing (where the marking are)? One of my motors is one of the JDM imports, could it be a JDM-only legit water-cooled VF-4? That is wrong. The strictly oil cooled EA-81Ts were VF1s. Early EA-82s were VF2s. I pulled a VF2 from an 85/86, IIRC. VF4s and VF7s followed in later years. The VF1 has noticeably smaller wheels. The VF2,4,and 7 are almost indistigushible. They are all RHB5s. RHB52s are a slightly different breed. Link to comment Share on other sites More sharing options...
