LPGsuperchargedBrumby Posted June 15, 2013 Share Posted June 15, 2013 Second, you need a minimum of 9.5:1 compression or a small engine like that will be a gutless t*urd and run like garbage. The EA81 runs fine on LPG....i know because i drove my one 25'000 miles after i converted before it had a hyro lifter failure that spalled the cam....i had the timing set way advanced....like i ran out of movement on the dizzy adjustment slot and ran it at that. it ran really well....well enough that i was pretty gutted at the time that i had to swap it out for an EJ Link to comment Share on other sites More sharing options...
m12-lrv Posted June 22, 2013 Author Share Posted June 22, 2013 This is awesome! Thanks for all the informative replies. Ive also noticed a huge increase in natural gas powered vehicles in my area, gonna look into it soon. Ive just been real busy with my newest toy. I must have subaru a.d.d. or something Link to comment Share on other sites More sharing options...
matts87glsedan Posted June 24, 2013 Share Posted June 24, 2013 (edited) http://www.ultimatesubaru.org/forum/topic/137844-matts-gl-sedan/ this is the propane system Ivan mentioned, i havent gotten anywhere with it yet, but it's there waiting for me. http://www.lgc.hk/ of course, i dont have a clue if its CSA certified or not. they have spfi ones too, but not sure if its the good venturi that was mentioned. Edited June 24, 2013 by matts87glsedan Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted June 25, 2013 Share Posted June 25, 2013 make sure your regulator is speced to rise rate with boost.... or if not make sure that you can compensate on the fuel map......i had to diagnose a EFI LPG problem that would make the car bog and die under boost, ran like a monster without boost....turned out to be when on boost the regulator pressure didn't rise with manifold pressure and there was no way of compensating in the fuel map....lol budget NA injection system fitted to a turbo motor= fail Link to comment Share on other sites More sharing options...
ivans imports Posted June 25, 2013 Share Posted June 25, 2013 I had to feed the propane into the turbo like a old turbo buick used a 425 mixer into a ej2.5 had to run draw thru Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted June 26, 2013 Share Posted June 26, 2013 I had to feed the propane into the turbo like a old turbo buick used a 425 mixer into a ej2.5 had to run draw thru .....Sir, please step AWAY from the intercooler and put the ignition keys down....... How did you wire it up so you only got spark without the ecu going on strike because the fuel injectors weren't returning the correct signal? or did you you run injector emulators? Link to comment Share on other sites More sharing options...
matts87glsedan Posted July 2, 2013 Share Posted July 2, 2013 (edited) make sure your regulator is speced to rise rate with boost.... or if not make sure that you can compensate on the fuel map......i had to diagnose a EFI LPG problem that would make the car bog and die under boost, ran like a monster without boost....turned out to be when on boost the regulator pressure didn't rise with manifold pressure and there was no way of compensating in the fuel map....lol budget NA injection system fitted to a turbo motor= fail So the manifold pressure wasnt allowing the regulated gas to enter into the manifold? damn. now that i think about it, the regulator has a vac line on it which i think needs to feel vacuum to allow fuel to flow at all... i dont think a fuel map change would fix that. but i could hopefully be wrong. Expect to hear some questions from me over the next little while, haha. Edited July 2, 2013 by matts87glsedan Link to comment Share on other sites More sharing options...
spazomatic Posted July 2, 2013 Share Posted July 2, 2013 Im keeping track of what y'all come up with here. The survivalist in me says that propane lasts forever, and i can fill up at home! Plus, i think itd be fun to build a 2.2 with a ridiculously high compression ratio. 1 Link to comment Share on other sites More sharing options...
ivans imports Posted July 3, 2013 Share Posted July 3, 2013 Has anyone tried adding a enrichment gasoline injector to a propane setup to add extra feul under load or boost can this be done. Like i do with my nos setup adding extra feul at same time as nos thru one commen injector Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted July 14, 2013 Share Posted July 14, 2013 it could be done....except that your ignition timing will be a bit far advanced for petrol if your using dizzy based ignition...ecu controlled ignition will compensate on the fly based on the knock sensor. you would be better off adjusting your propane A/F under boost rather than putting a lower octane fuel into the mix...but thats just my $0.02 minus tax Link to comment Share on other sites More sharing options...
rdweninger Posted September 23, 2013 Share Posted September 23, 2013 Well, I'm back after a few months off. My Mom passed away June 30. Just picked up an '81 Brat. The fuel tank is gone. Carb is probably shot, due to the motor not running since 2008. Anyway, this seems like a good candidate for LP conversion. So, what do I need? And where do I get it? It's good to be back... Let's see who's out there Ron w. Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted September 27, 2013 Share Posted September 27, 2013 (edited) you will need a filler inlet (Acme 1 3/4" from memory seeing as your in the states) the hose from filler to tank, the tank and mounts/brackets, hose or tube from tank to engine bay, a lock-off valve(either vac or electric), a regulator/vapouriser, hoses to hook regulator to heater hoses, line from regulator to mixer/carb and finally a carburetor/mixer....plus assorted fittings to connect hoses to tank, regulator etc Edited September 27, 2013 by LPGsuperchargedBrumby Link to comment Share on other sites More sharing options...
