marcusgl10z28 Posted May 21, 2013 Share Posted May 21, 2013 Just want to figure out if anyone knows where I can get them if at all... or mabey someone has a whole window assembly laying around... rails and all... its summer I want to open mine but its washington so I wajt to be able to close it at a moments notice also...please help Link to comment Share on other sites More sharing options...
shortysayhi Posted May 21, 2013 Share Posted May 21, 2013 I have the whole assembly (rails, motor, glass) ITs a big thing to ship tho... Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 21, 2013 Author Share Posted May 21, 2013 I was hoping I could find someone local... I'm tired of ducttape all year... the sunroof works it just wont seal... started after I jumped it and hit my head real hard on in and spidered the inner layer of glass now it just dosent line up at the rear driver corner.... depending on how far you are I may snag it but shipping on bulky stuff is killer Thank you though Link to comment Share on other sites More sharing options...
shortysayhi Posted May 22, 2013 Share Posted May 22, 2013 try pulling your WHOLE roof piece and see if theres a way you can adjust it (i think there is). Link to comment Share on other sites More sharing options...
ivans imports Posted May 22, 2013 Share Posted May 22, 2013 i have a whole one out but is a big peice Link to comment Share on other sites More sharing options...
ivans imports Posted May 22, 2013 Share Posted May 22, 2013 there are shims under the glass were it mounts to addjust height Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted May 22, 2013 Author Share Posted May 22, 2013 What do you mean by under the glass? Mabey a stupid question... but I didn't see a place for adjustments. And does anyone have the slide cove for them.... or was there evn on... it wasn't there when I got the car but think there are rails for it... blue would be best if anyone has a spare thanks for the help. And I may be interested in the glass at some point... it spidered from my head hitting it but its not broken yet Link to comment Share on other sites More sharing options...
ruparts Posted May 22, 2013 Share Posted May 22, 2013 (edited) Just want to figure out if anyone knows where I can get them if at all... or mabey someone has a whole window assembly laying around... rails and all... its summer I want to open mine but its washington so I wajt to be able to close it at a moments notice also...please help Hi, If you are having a problem with a water leak, it's more likely the drain tubes are clogged. it is common and not too hard to clear them . water from outside the roof is not totally sealed completely by the seal,, some water that does get in , is caught in a trough in the inner assembly and there is a drain hole at each of the corners. there is a rubber like tube from there down the windshield pillar to a point beneath the front fender on the door pillar. you don't have to remove anything to clear the drains . i have had best luck using a 1/16" braded cable, available at hardware stores and use it like a roto rooter through the holes and down the tubes . you can flush them out afterward with a little water to check if it is clear. if you open the glass you can find the drain holes in the front corners,, not too sure but i think the rears are accessable there too. you might also be able to blow compressed air through them to clear them. anyway most leaks are because they are clogged and the runoff trough gets full and overflows basically onto the headliner. BTW the roof glass is kinda tricky to adjust if you remove it ,, i would not advise doing it unless it is really necessary . i bet your inside leak will stop if you get the drains clear. Edited May 22, 2013 by ruparts Link to comment Share on other sites More sharing options...
rdweninger Posted May 22, 2013 Share Posted May 22, 2013 Sorry about your head... man. That's why we 'professionals' wear helmets! Link to comment Share on other sites More sharing options...
ivans imports Posted May 23, 2013 Share Posted May 23, 2013 on the glass if you look were the glass joins the frame under the plastic trim you will see 8mm nuts holding it down under those nuts are horseshoe shaped shims to addjust height of glass Link to comment Share on other sites More sharing options...
