Fairtax4me Posted June 5, 2013 Share Posted June 5, 2013 The device under the intake is the purge solenoid for the evap canister. One hose should go to the canister the other to the manifold. IIRC that hose should loop up to a port in the center of the intake manifold on top right in front of the throttle body. It sticks straight up. If that one is taken just run a T off of it. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 5, 2013 Share Posted June 5, 2013 (edited) http://txtup.co/iVJPd ALSO there is a device under the intake on the right hand, rear side that has a vac hose and some wires running to it, but its not hooked up to a vac hose, and IO don't recall unhooking it, nor is there a port to hook it up to sounds like the Purge valve - could be your Evap code problem (some older soobs have that in the back, some under the hood - I dunno which years so, I might be wrong) Hose should go to the intake IF it's the purge valve - not sure if it's routed to near the throttle body or exactly where.....maybe dig around at opposedforces.com for a diagram for your car. DOH - didn't see the next page before replying Edited June 5, 2013 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
ivans imports Posted June 5, 2013 Share Posted June 5, 2013 um try tighting the ground bolt on intake ps side also check main engine conectors on engine to car harness like to not plug in all the way also check alt voltage is not to high when i get cars with mutiple codes is uhsaly somthing biger going on sensers do not fail that easy and mutiple frailed sensers very very rare car ecu having to learn no dont think so i put in engines dayliy and its ether right or wrong. Should be runing as good as its going to as soon as you start it. Link to comment Share on other sites More sharing options...
mightGETaSUBARU Posted June 5, 2013 Author Share Posted June 5, 2013 I would say with the exception of the purge valve thing this is solved the fuel trims look a lot better Link to comment Share on other sites More sharing options...
