Suba_GL_87 Posted May 27, 2013 Share Posted May 27, 2013 (edited) whats your most tends for repair of rod/main bearing size? .020" (2000 ej25) Edited May 27, 2013 by Suba_GL_87 Link to comment Share on other sites More sharing options...
Legacy777 Posted May 28, 2013 Share Posted May 28, 2013 Are you asking what the most typical oversized bearings are? I would think you can probably get bearings in either .020" or .040" oversized. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 14, 2013 Author Share Posted June 14, 2013 yes, thats what i ask for. i was order STD. Conn. & main bearing and seem too tight. also wrong size main bearing look small... not like as old main bearing. Link to comment Share on other sites More sharing options...
Gloyale Posted June 14, 2013 Share Posted June 14, 2013 If you got bearings for a phase I EJ25 they will have smaller Con rod bearings. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 25, 2013 Author Share Posted June 25, 2013 and main bearing too? Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 26, 2013 Share Posted June 26, 2013 Main bearings on 25D have thrust bearing in a different place. 25D thrust bearing is in #3 position IIRC 251 is in # 5 Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 29, 2013 Author Share Posted June 29, 2013 On 6/26/2013 at 12:48 AM, Fairtax4me said: Main bearings on 25D have thrust bearing in a different place. 25D thrust bearing is in #3 position IIRC 251 is in # 5 52MM? thrust bearing? Link to comment Share on other sites More sharing options...
