78 Subaru 4x4 shifting clunk
Hey USMB,
   Have a question for you guys out there. I was testing out my 4x4 for the first time a bit ago. She engages ok and the 4wd light comes on. She drives down the road fine. When I stopped to pull her out of 4wd to 2wd it took a bit of strength to pull the lever down and then I heard a big clunk. It almost had a tight wound up feel in the rear end if that makes sense. Any ideas? Is this normal?
Were you using 4wd on dry pavement? If you were, then yes, it's normal to bind up the driveline like that. It's also bad for it, don't use 4wd on dry pavement. Ever.
It's fine on dirt, snow, if it's really rainy/hydroplaning on the highway, etc. But nice hard good traction surface, you'll break something using 4wd.
