ea81 brake experts? couple of q's.
I've got a strage problem Austin and I incountered while getting my brakes blead. 2 of the wheels, the passenger side front wheel, and the drivers side rear wheel blead correctly or as expected, the passenger side rear wheel, and the driver's side front wheel however were very difficult to bleed. And aparently theres a small brake fluid leak in the system someware, I'm wondering if the bleeding symptoms are normal, or not. I'm gonna crawl under the car here when I get a chance to look for that brake fluid leak, but if anyone has any knowledge on how they're suposed to bleed, or why they don't bleed correctly, it's much apreciated, thanks everyone.:)
If the brakes have not been bleed in many years you could have particles of junk plug the bleeding nipple. Also you could have a flexible line that is coming apart inside working like a one way valve, seen this on a old chevy truck once.
ok, so when I get a chance, I'm going to bleed the master cylender, and hill holder, then I'm gonna go looking for the fluid leak, for all I know it could be a leaky bleeder nipple on the MC. Anyway, then I need to get new front roters and brake pads lol:banghead:
