1988 GL FI Stutters/Hesitates Upon Acceleration
When I depress the gas while driving, the car will stutter and hesitate for a bit and then accelarate, but then after a bit will stutter and hesitate.  However, while idleling in neutral and depressing the gas pedal, the motor revs fine - -getting gas, I assume not fuel pump (changed fuel filter today).  What else should I look at?
Check for any loose hoses, cracked and brittle vac hoses, etc.....but if you don't find anything obvious there, change your sparkplugs and possibly the wires too if they are old.
NGK plugs.
  • Like 1
