edrach Posted October 13, 2013 Share Posted October 13, 2013 (edited) This post is an error. You want to order Dorman p/n 610-320! See my next post with an explanation and more information. I was planning to head out to the local pull a part yard and knock out 10 studs for my two adapters. Then I found this: http://www.amazon.com/Dorman-610-378-12Mm-12-5-42Mm-Wheel/dp/B000CISZLG/ref=sr_1_3?ie=UTF8&qid=1381675239&sr=8-3&keywords=nissan+pathfinder+wheel+studs on amazon. For 10, my total cost was $22.69 after standard shipping was added. It pays to shop around. Entering the Dorman part #610378 into the Rockauto catalog, I came up with a package of 10 shipped for $14.92! Either option beats grovelling on the ground at pull a part after figuring in your time, gas, and access cost to the yard. Edited October 13, 2013 by edrach Link to comment Share on other sites More sharing options...
matts87glsedan Posted October 13, 2013 Author Share Posted October 13, 2013 hi everyone. confirming my material order this morning. unfortunately, only 1 inch plate is available, meaning that the actual offset will be the same as the prototype at .8 inches. on the bright side, this will bring down the cost some. forgot to address this. i should have kept my mouth shut until the bill was paid... the 'off the cuff' verbal quote i got was 30% cheaper than the actual bill. i ended up paying exactly the same price to these guys for the thinner material as i would have for the thicker stuff at the other shop. but I would have had to wait 6 weeks to get them. so ya... no price reduction. i am continuing to update the first post with 'official' information - specs, price, etc. Link to comment Share on other sites More sharing options...
Turbone Posted October 13, 2013 Share Posted October 13, 2013 well there's been some interest in my adapters, so im starting a vendor thread. heres the prototype: I have about 5000km on these, no problems yet. Stock material is 6061 T6 aluminum. standard material for all internet wheel spacers. MOUNTING INFO the 4x140 pattern is tapped with a M12 x 1.5 thread to facilitate bolting through the original stud holes to the hub. i will supply M12 x 30mm class 10.9 mounting bolts. you need to knock out your studs and put the bolts in their place, torque is 72 ft-lbs, blue locktite MANDATORY! retorque after 100kms. STUD INFO - DORMAN 610-320 is recommended the 5 x 100 pattern is drilled for an M12 1.25 stud with a 12.8mm knurl. the stud head size that i used was 19mm dia, by 4.5mm deep. check your stud head diameter and thickness before installing. you may need to grind them a bit. these holes are a PRESS FIT. i had to put about 1000psi on mine to get them seated - i may make that a little looser, lol. but you really don't want them to spin, so tight is good. Length of studs needed is M12 x 40mm long. Nissan pathfinder studs are M12 1.25 x 41.5mm - they should be close enough, you make the call. I am not providing studs. CENTER BORE its 1.98 inches. you may have to grind your 36mm socket. mine fits. RIM CENTERING these provide a 7/8 offset, with a 3.5mm tall lip to center the rim on. price will be 60$ a piece. for one adapter and 4 mounting bolts thanks soobydoo, capn_r , 86BRATMAN, and bratman18 for the initial interest here: http://www.ultimatesubaru.org/forum/topic/137844-matts-gl-sedan/ edit note - i am filling in the necessary finalized details in bold , as i nail it all down. I'm quoting it so it brings it up on this page. Link to comment Share on other sites More sharing options...
edrach Posted October 13, 2013 Share Posted October 13, 2013 Sorry about posting an error. Interesting how I got there. I did a search on Amazon for Nissan Pathfinder studs and came up with the wrong number. Using that number I ordered a set of 10 from Rockauto. Fortunately, Matt caught the error and texted me the correct Dorman part number. Since it was Sunday, I called Rockauto (they are answering the phone today!!!) and cancelled my original order. Then went back and ordered the correct item. So finally the correct info is: Dorman p/n 610-320 from Rockauto: Bag of 10 for $15.32 shipped to my work address. Link to comment Share on other sites More sharing options...
matts87glsedan Posted October 13, 2013 Author Share Posted October 13, 2013 (edited) *edit* oops, everyones on it already http://www.dormanproducts.com/p-8096-610-320.aspx?year=1996&make=Nissan&model=Pathfinder&parttype=Wheel%20Stud%2FBolt Edited October 13, 2013 by matts87glsedan Link to comment Share on other sites More sharing options...
matts87glsedan Posted October 13, 2013 Author Share Posted October 13, 2013 (edited) Sorry about posting an error. Interesting how I got there. I did a search on Amazon for Nissan Pathfinder studs and came up with the wrong number. Using that number I ordered a set of 10 from Rockauto. Fortunately, Matt caught the error and texted me the correct Dorman part number. Since it was Sunday, I called Rockauto (they are answering the phone today!!!) and cancelled my original order. Then went back and ordered the correct item. So finally the correct info is: Dorman p/n 610-320 from Rockauto: Bag of 10 for $15.32 shipped to my work address. it is still a pathfinder stud, just for a new one, not an old junkyard pathfinder. glad they cancelled it for you. you guys get much better deals on studs in the 'states. best canadian deal i could find was almost 4$ a piece, haha Edited October 13, 2013 by matts87glsedan Link to comment Share on other sites More sharing options...
edrach Posted October 13, 2013 Share Posted October 13, 2013 (edited) it is still a pathfinder stud, just for a new one, not an old junkyard pathfinder. glad they cancelled it for you. you guys get much better deals on studs in the 'states. best canadian deal i could find was almost 4$ a piece, haha You might try to see if rockauto will ship to Canada. I checked Amazon (they probably ship to Canada) and the best price for the 610-320 I could find there was $2.29 (US) each plus shipping.Still not a bargain, but almost half price compared to what you were getting.. Edited October 13, 2013 by edrach Link to comment Share on other sites More sharing options...
matts87glsedan Posted October 17, 2013 Author Share Posted October 17, 2013 Done, this is now The Official List: 86BRATMAN - 1 pair edrach - 1 pair dudesmccool - 2 pair subaruguru - 2 pair soobydoo - 2 pair 86GLAK - 2 pair ftwneon - 2 pair i will edit this post as others sign up... feel free to spread the word . once i get to 20 pieces , i'll order the material. heres where things are right now. 86Bratman - out edrach - paid and shipped dudesmccool - out subaruguru - did not reply soobydoo - did not reply 86GLAK- out ftwneon - unconfirmed so i have 5 pairs officially up for grabs. I'm waiting on replies from okvaa, and seventythree. Turbone, looks like a pair is yours - i'll PM you Link to comment Share on other sites More sharing options...
MuddyThunder Posted October 20, 2013 Share Posted October 20, 2013 What will a set of 4 cost to Oregon 97402..? please pm me with price thanks, Wyatt. Link to comment Share on other sites More sharing options...
matts87glsedan Posted October 21, 2013 Author Share Posted October 21, 2013 seventythree is now paid and shipped, thank you! muddythunder - i will pm you tomorrow Link to comment Share on other sites More sharing options...
MuddyThunder Posted October 21, 2013 Share Posted October 21, 2013 Thanks matts87.....looking forward to it... Link to comment Share on other sites More sharing options...
edrach Posted October 21, 2013 Share Posted October 21, 2013 Hubs arrived today, thank you. I'll make sure I have my stuff together and have the studs pressed in this week. Hopefully the adapters will be mounted on the brat this weekend. Link to comment Share on other sites More sharing options...
88HatchMonster Posted October 21, 2013 Share Posted October 21, 2013 Hubs arrived today, thank you. I'll make sure I have my stuff together and have the studs pressed in this week. Hopefully the adapters will be mounted on the brat this weekend. I'd love to hear and see how they work out on the brat! Link to comment Share on other sites More sharing options...
edrach Posted October 22, 2013 Share Posted October 22, 2013 Hubs arrived today, thank you. I'll make sure I have my stuff together and have the studs pressed in this week. Hopefully the adapters will be mounted on the brat this weekend. Update: My craftsman 36mm socket fits fine through the center bore. Also pressing the studs out of the old wheel hubs is proving to be harder than I expected. Too much rust. Link to comment Share on other sites More sharing options...
matts87glsedan Posted October 22, 2013 Author Share Posted October 22, 2013 Update: My craftsman 36mm socket fits fine through the center bore. Also pressing the studs out of the old wheel hubs is proving to be harder than I expected. Too much rust. glad they got there, i was wondering. too bad about the rusty hubs, all mine knocked out with a BFH quite easy. Link to comment Share on other sites More sharing options...
matts87glsedan Posted October 22, 2013 Author Share Posted October 22, 2013 heres where things are right now. edrach - paid and shipped 1 pair subaruguru - did not reply soobydoo - did not reply ftwneon -now confirmed sventythree- paid and shipped 2 pair okvaa- paid for 2 pair changes to the list Link to comment Share on other sites More sharing options...
edrach Posted October 23, 2013 Share Posted October 23, 2013 (edited) glad they got there, i was wondering. too bad about the rusty hubs, all mine knocked out with a BFH quite easy. You must have newer hubs. But it wasn't a problem. I let them soak for 2 hours with some Yield and the press took them out much more easily now. Somehow I wasn't comfortable with the BFH. Edited October 23, 2013 by edrach Link to comment Share on other sites More sharing options...
Subarutex Posted October 23, 2013 Share Posted October 23, 2013 I'm interested in a set of 4 of these if there are any still available. Confirmed to work on the front and rear of a EA82 w/ disk brakes all around? Link to comment Share on other sites More sharing options...
edrach Posted October 24, 2013 Share Posted October 24, 2013 I'm interested in a set of 4 of these if there are any still available. Confirmed to work on the front and rear of a EA82 w/ disk brakes all around? Tex, I should have mine ready to install shortly. You can check them for fit if you need to. I won't be able to mount on the Brat for a week or two for reasons unrelated to the adapters. Link to comment Share on other sites More sharing options...
88HatchMonster Posted November 25, 2013 Share Posted November 25, 2013 Let's see some pics of these fitted up with 5 lugs! I'm really curious how they sit on the Brats especially, but would love to see on EA82 also... Link to comment Share on other sites More sharing options...
edrach Posted December 1, 2013 Share Posted December 1, 2013 Whole bunch of reasons, but I haven't mounted them yet. Will post when they are.....hopefully before the new year. Link to comment Share on other sites More sharing options...
izik Posted December 7, 2013 Share Posted December 7, 2013 Hello, I saw the invitation that you did and I wanted to Know if I can order from you this set(wheels) for Subaru brat 1979 and what is the price? Link to comment Share on other sites More sharing options...
spicypeanut Posted December 19, 2013 Share Posted December 19, 2013 Can you PM me the price for a set of 4 for my 78 brat? Link to comment Share on other sites More sharing options...
88HatchMonster Posted January 18, 2014 Share Posted January 18, 2014 Still really want to see these guys on an EA81/gen2! Wondering how they space the wheels and how they sit in the fender wells etc. Plus just think they will look sweet and want to see! Also are there still 4 left? If not, will you do another run at some point? Thanks! Link to comment Share on other sites More sharing options...
sull Posted February 2, 2014 Share Posted February 2, 2014 I'm interested in a set shipped to NY or CT. Any left? Link to comment Share on other sites More sharing options...
