used car Posted June 8, 2013 Share Posted June 8, 2013 1987 Subaru gl 3 speed automatic I have been having clunking,grinding type noises from front end when accelerating from a stop.Does not do it at other times.I have taken the advise of some of the replys to my previous posts on Subaru forum.Have replaced both front cv axles,wheel bearings and left hub.What else could it be??? .No one in this town knows! Is there someone who has a idea? I don't want to junk it. Car has only 87,000. Engine runs good. Thanks............Used Car Link to comment Share on other sites More sharing options...
MR_Loyale Posted June 8, 2013 Share Posted June 8, 2013 How are motor mounts? 1 Link to comment Share on other sites More sharing options...
mikaleda Posted June 8, 2013 Share Posted June 8, 2013 Yep check the motor mounts, but did you inspect the right hub as well? Also check your muffler system, I had a weird noise in my 80 for a long time that made me think I had a bad bearing, it turned out to be my muffler scrapeing against the rear end hanger because the p.o. Used a bungee cord to hold the muffler mounts and every time I stepped on the gas it would flex just enough to make it scrape and sound like a banging grinding noise. 1 Link to comment Share on other sites More sharing options...
used car Posted June 8, 2013 Author Share Posted June 8, 2013 Need more advice Subaru people.No one in my town has ever seen a Subaru gl car. Thanks! Link to comment Share on other sites More sharing options...
Prwa101 Posted June 9, 2013 Share Posted June 9, 2013 Is it an 4wd awd model? Are all the tires the same size? Link to comment Share on other sites More sharing options...
Dee2 Posted June 9, 2013 Share Posted June 9, 2013 have you checked the brakes ? 1 Link to comment Share on other sites More sharing options...
MR_Loyale Posted June 9, 2013 Share Posted June 9, 2013 An audio or video would be helpful. Link to comment Share on other sites More sharing options...
used car Posted June 9, 2013 Author Share Posted June 9, 2013 (edited) Is it an 4wd awd model? Are all the tires the same size? Yes it is.. Frt.wd with 4wd on demand.Good same size tires. Edited June 9, 2013 by used car Link to comment Share on other sites More sharing options...
used car Posted June 9, 2013 Author Share Posted June 9, 2013 have you checked the brakes ? No. What could be wrong with them that would cause this problem? Link to comment Share on other sites More sharing options...
used car Posted June 9, 2013 Author Share Posted June 9, 2013 have you checked the brakes ? No i have'nt .Why? Link to comment Share on other sites More sharing options...
mikaleda Posted June 9, 2013 Share Posted June 9, 2013 It could be a pad that is stuck or loose causing the noise. it wouldn't be a bad idea to do a brake inspection and maybe grease the slide pins Link to comment Share on other sites More sharing options...
Lacyjs9 Posted June 9, 2013 Share Posted June 9, 2013 id closely inspect the hub since you replaced the axles when i got mine it would pop and click every once and a while then i drove 300 constant miles and it got worse and constant upon further inspection i found this Link to comment Share on other sites More sharing options...
rdweninger Posted June 10, 2013 Share Posted June 10, 2013 I had a grinding noise on my '85 wagon. 85,000 miles. My finely tuned hearing sense lead me directly to the left rear hub. Pulled the brake drum and found what was left of a few brake springs and clips. As others have suggested..... CHECK YOUR BRAKES !!! Link to comment Share on other sites More sharing options...
NickNakorn Posted June 11, 2013 Share Posted June 11, 2013 Try and judge if the noise is in time with your wheel rotation or your engine rotation. I once had a very similar sound on a Daimler Majestic Major and it turned out to be a loose bolt in the torque converter bell housing. Having mostly had manual cars I didn't find the fault but a friend who had driven many automatics recognised it. It's just a suggestion if you find nothing else wrong with the wheel/axle/hub assemblies. 1 Link to comment Share on other sites More sharing options...
