nobangmycar Posted June 8, 2013 Share Posted June 8, 2013 Tee hee, just fitted new EA71 for my '78 DL Sedan and just plugging everything back up and I've forgotten where the battery earth was. On the block or the car? Where abouts? Silly question I know... Link to comment Share on other sites More sharing options...
-tombba- Posted June 8, 2013 Share Posted June 8, 2013 If you mean the wire apart from the main lines (comes straight from the battery terminal). In my EA71 it goes to the valve cover bolt. That small wire is only for grounding the engine. Link to comment Share on other sites More sharing options...
mikaleda Posted June 8, 2013 Share Posted June 8, 2013 Large wire to the engine block just above the right hand side valve cover, small wire goes to the chassis Link to comment Share on other sites More sharing options...
mikaleda Posted June 8, 2013 Share Posted June 8, 2013 Here is a pic for the block ground I replaced the original with a #4 AWG welding lead and it seems to like it better. Link to comment Share on other sites More sharing options...
nobangmycar Posted June 8, 2013 Author Share Posted June 8, 2013 Sweet! Thanks very much for your help. Link to comment Share on other sites More sharing options...
