95-99 Legacy, Impreza, Forester
take a picture of your ABS mounting position and any knuckle that has that position i think is your money maker. i think on older ones the  ABS sensors goes in horizontally pointing away from the car and on newer stuff it mounts nearly vertically "pointing down" so to speak.
swap your brake caliper bracket onto the donor knuckle.
all 95-99 struts, axles, and ball joints are interchangeable or the same (SVX has 113mm stud spacking though).  so the steering knuckles are also interchangeable, just make sure it has ABS - not all do in the late 90's.  i think even FWD are the same, but inspect carefully i'm not positive.
the ABS set up changes around 2000 or so but varies with model i think - the tone ring goes from being in the knuckle to being on the axle.
though you can install newer axles on older subarus if you simply knock the tone ring off the axle, so the knuckles are still very similar, but the ABS mounting changes.
  On 6/10/2013 at 4:27 AM, grossgary said:
oh no, sorry, i just meant Subaru used so many different caliper, bracket, pin verses bolt styles and differeing sizes that it's good to keep the bracket with the vehicle.
indeed enjoy the west, all is well here.
Awesome, thanks!  Yes the west is treating us right.  Though the east beckons.  In fact we'll be in WV for a wedding in late July.  I'm not sure of the exact location yet, but somewhere near the Canaan Valley.  Don't know if you're in the hood, but maybe we could meet up for a "how do ya do"
sure, that would be awesome. i'm about two hours from there. youre at a wedding and traveling and i have two young children so time is very limited.  PM details.
that's a nice area, we go cross country skiing at a fantastic place there.
Edited by grossgary
PM Sent
