I replaced the brake pads and rotors front and back on my 2001 Subaru Forester S. a a week ago. Today I noticed that the ABS light came on. The brakes have been great otherwise.  Any thoughts would be appreciated. Thanks
best bet is to read the code, otherwise there's nothing to go on.  just above the gas pedal is a connector, ground one of the pins in it and the ABS light will flash the code for you.  a google search will show pictures of the connector and which pin to ground with the also connected grounding pin taped into the wiring harness.
