chris.dedrickson Posted June 15, 2013 Share Posted June 15, 2013 installing cyl. heads on 98 outback ej25 need torque specs and sequence for camshaft and seal caps. also timing info please. thanks! Link to comment Share on other sites More sharing options...
SubieTrav Posted June 15, 2013 Share Posted June 15, 2013 Here is the FSM for the 1998 2.5 DOHC. https://docs.google.com/folder/d/0B6P6dybMMzg9OTN0bkJ2RnJrMlk/edit?pli=1 thought I'd add the rest of the FSM for the 1998 Legacy in case you might be interested. They come in handy. https://docs.google.com/folder/d/0B6P6dybMMzg9T25hMEhPdjFVc1k/edit?pli=1 Link to comment Share on other sites More sharing options...
SubieTrav Posted June 15, 2013 Share Posted June 15, 2013 BTW, welcome to USMB. Link to comment Share on other sites More sharing options...
Svengouli7 Posted June 16, 2013 Share Posted June 16, 2013 careful on those seal cap bolts. Easy to sheer. Link to comment Share on other sites More sharing options...
davebugs Posted June 16, 2013 Share Posted June 16, 2013 On 6/16/2013 at 12:34 AM, Svengouli7 said: careful on those seal cap bolts. Easy to sheer. Especially the smaller ones towards the front IIR. Note there are TWO torgue's - one for the rest of the bolts and something less fo rthe lighter ones on the end. Link to comment Share on other sites More sharing options...
johnceggleston Posted June 16, 2013 Share Posted June 16, 2013 Quote careful on those seal cap bolts. Easy to sheer. Quote Especially the smaller ones towards the front IIR. Note there are TWO torgue's - one for the rest of the bolts and something less fo rthe lighter ones on the end. there are in fact two different torque specs. pay attention. Link to comment Share on other sites More sharing options...
spike666 Posted October 9, 2013 Share Posted October 9, 2013 Hello, I'm new to the board. I came here for advice on this same topic. What would be the torque sequence and torque as in ft lbs. be for a 1997 dohc? Something in noob form. I dunno how to read what it says in the google doc, this bit below. Tightening torque: N·m (kg-m, ft-lb)T1: <Ref. to 2-3b [W4E0].>T2: 5 (0.5, 3.6)T3: 10±0.7 (1.0±0.07, 7.2±0.5)T4: 20±2 (2.0±0.2, 14.0±1.4) I read also that it's a sequence in 2 progressive steps to 14.5ft lbs. What does the 2 progressive steps refer to? Sry if I sound like I've never done this before, that's because it is my first time. I need to change head gaskets. I just don't want to over torque the bearing cap bolts. So if someone can explain it in an easy step by step guide and show the torque pattern that would be GREAT! Thanks, John Link to comment Share on other sites More sharing options...
spike666 Posted October 11, 2013 Share Posted October 11, 2013 Nvm. I figured it out and got my head gaskets in. Link to comment Share on other sites More sharing options...
