Mark Humble Posted June 18, 2013 Share Posted June 18, 2013 I decided since the a/c system on my 89 GL had a small leak in the compressor, I would see what would happen if I charged it with R134a without removing the old oil or doing anything to the system. So I put in the refrigerant and oil that was in the kit and started using the a/c. It has never worked better since I've owened the car. The small gasket leak is still there but has slowed down alot. Only time will tell if anything bad will happen. After talking with several A/C techs, and getting several different opinions as to what should be done to convert the system and why, I decided to see for myself what would happen if I didn't convert it properly. I don't use the a/c much and don't really care if it never works again. Mark Link to comment Share on other sites More sharing options...
SmashedGlass Posted June 18, 2013 Share Posted June 18, 2013 Waiting to see what happens also Not too keen on the $250+ price tag to convert after I repair my system. Link to comment Share on other sites More sharing options...
rain_man_rich Posted June 18, 2013 Share Posted June 18, 2013 Which kit did you use? Link to comment Share on other sites More sharing options...
kanurys Posted June 18, 2013 Share Posted June 18, 2013 If it doesn't work, see how long the compressor will last without lube, setup as an air compressor for on-board air. Link to comment Share on other sites More sharing options...
Numbchux Posted June 18, 2013 Share Posted June 18, 2013 I've got 2 years on the kit I got at wal-mart on my '92 Celica. I've had to recharge it every spring, but it holds through the entire summer. I might try a better recharge that has some stop-leak stuff in it this year. It might not be the "correct" way, but it seems to work great, at least for a few years. Link to comment Share on other sites More sharing options...
Mark Humble Posted June 19, 2013 Author Share Posted June 19, 2013 The kit I used was made by Interdynamics, Inc, Model#RKR-5. It was given to me by a co-worker, he had bought it a long time ago and never used it. The box was all rotted and the cans rusty but it worked. I did see they sell refrigerant with the oil and stop leak yesterday while at the auto parts store, I may try some when the system leaks down some. Mark Link to comment Share on other sites More sharing options...
rain_man_rich Posted June 19, 2013 Share Posted June 19, 2013 Great! That's the one I've had my eye on for a while. I think I'll give it a go. Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 19, 2013 Share Posted June 19, 2013 Just make sure to cross out the A/C lable under the hood and write R134a next to it in permanent marker. When someone down the road goes to recover the refrigerant and sucks a r134a mix into their r12 tank it will ruin their day. Link to comment Share on other sites More sharing options...
Mark Humble Posted July 14, 2013 Author Share Posted July 14, 2013 Well, it's been nearly a month now and the A/C is still working great. The leak in the compressor seems to have stoped and I have not had to add any refrigerant. The compressor cycles on and off as normal. Its been hot here, but not in my car. Mark 1 Link to comment Share on other sites More sharing options...
