Rear Drive Botched Repair 1995 Subaru Legacy
'95 Subaru Legacy
Doing this myself.....Need Help
Good fuse
Click test (good?) duty C solenoid
Passable AWD clutch pack installed (Pick a Part)
Had "KG" Marked TCU
Tried 1996 "PC" TCU.....still no RWD
Any suggestions?
what he said .
or
do you have a CEL on the dash?
does your speedo work?
if your front speed sensor fails, you will not have power to the rear.
or
if you have a busted rear axle, very very rare, you will have no power to the rear wheels.
Edited by johnceggleston
No, I checked the main fuse under dash.
Axles will pop out?
Let me see.
Where exactly is the "front speed sensor"?
By "busted rear axle" did you mean the main carrier or an axle shaft?
I'll check the back wheels turning.
Every AWD clutch pack I've ever seen had grooves cut into it.
I thought since it worked the day before that pressure and vibration pushed them over anyway.
When I had the tail cone off I didn't see any chamber that would hold air.
Never lit the CEL
No code for transmission
Turned both back wheels at once - drive shaft did turn
Turned left and right independently with other wheel stopped - drive shaft did turn
Left front wheel speed sensor shows continuity.
Front wheels pulling all & chirping was the first indicator we had to the problem.
Please, what would wet grass tell me?
when the tailshaft assembly is on bench install clutch pack into its bore then can air check thru the feed port and see if drum piston moves and locks up pack i take the rear trans output shaft and drop it into pack then i can turn clutches and see if is locking
