ivans imports Posted June 19, 2013 Share Posted June 19, 2013 Have a 98 outback came in smashed rebiult it now fans will not shut off they run whenever car is running ac is disconected is weird have never had thiss before tried unpluging heater control no diff changed ecu no diff any ideas anyone had thiss happen before. Also have been geting many of theese cars with only the ds fan working is there somthing in the fan control i'm missing like a one way diode or override realy or somthing driving me nuts Link to comment Share on other sites More sharing options...
johnceggleston Posted June 19, 2013 Share Posted June 19, 2013 only when the test connectors under the dash are connected. green i think. Link to comment Share on other sites More sharing options...
Gloyale Posted June 19, 2013 Share Posted June 19, 2013 CTS incorrect or not hooked up? Link to comment Share on other sites More sharing options...
davebugs Posted June 19, 2013 Share Posted June 19, 2013 Remember there are 2 CTS - one for the dash, one for the ECU. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 20, 2013 Share Posted June 20, 2013 Radiator fan is running all the time? Tried swapping relays? If its the interior blower fan there is a short between the fan and switch. The fan is constantly powered w/ key ON and is grounded through the resistor block and speed switch. Link to comment Share on other sites More sharing options...
ivans imports Posted June 20, 2013 Author Share Posted June 20, 2013 Treid diffent realys treid differnt heater switch fan realy fan motor cts when disconected car changes and sets cel so think its working car has no cel on when running is like the realy is getting trikkle voltage from somwere just enuff to turn on realy. not very often i struggle with somthing but cant figure thiss one out. I wonder if a bad alt could do thiss ? just cant get the rad fan to shut off Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 20, 2013 Share Posted June 20, 2013 ECU grounds the fan relays. If you're sure there isn't a short between the relays and ECU, the ECU is bad. Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 21, 2013 Share Posted June 21, 2013 The fail safe for a bad coolant temp sensor reading is for the ECU to command the fans on fulltime, but it should also set a code at the same time. I would check over the harness in the area that the car was smashed. I fixed a forester that had some really strange electrical issues caused by a twist n' tape repair to the harness in the left front corner. They taped the wires together with duct tape, then used electrical tape to bundle the harness back together so it looked right. Took a bunch of solder and shrink tubing to get it back working right. Link to comment Share on other sites More sharing options...
ivans imports Posted June 21, 2013 Author Share Posted June 21, 2013 Thats were i'm at tear into the harness tried a differnet ecu dident help the harness looks untouched from wreak couldent find any damage that i could see. I will take the conduate off and look closer. Have been having fan problems on same cars but is ushaly a ps fan that wont turn on There has to be more to the fan curcit than I a'm seeing Link to comment Share on other sites More sharing options...
