jonas Posted June 22, 2013 Share Posted June 22, 2013 Replaced a blown fuse and still nothing. They were working just fine. Everything else works. Checked the 3 links in the grey plastic cover on the passenger side, all good. was thinking bad light switch but all my other lights work just fine. *scratches head* Link to comment Share on other sites More sharing options...
BratRod Posted June 23, 2013 Share Posted June 23, 2013 Still starts? I would try testing for continuity among the ground straps. My Brat had the same problem. It ended up being a combination of: ground strap, blown fuse, and melted wire due to PO putting a 40amp fuse in there... Link to comment Share on other sites More sharing options...
mikaleda Posted June 23, 2013 Share Posted June 23, 2013 It could still be a bad switch, I would pull the switch and check it out. Link to comment Share on other sites More sharing options...
jonas Posted June 23, 2013 Author Share Posted June 23, 2013 thanks guys. will be checking the switch in a few min. where are those grounds located? Link to comment Share on other sites More sharing options...
jonas Posted June 23, 2013 Author Share Posted June 23, 2013 Ok, pulled the switch and the male/female connector from the switch into the harness is absolutely FRIED! Peeled back about 4 inches of the harness casing and all the wires look fine. Looks like a trip to the boneyard for new switch and connector is in order. Last time I was there all they had was an '80's hatch. Hope it's still there. Link to comment Share on other sites More sharing options...
