jmoss5723 Posted June 23, 2013 Share Posted June 23, 2013 2004 Forester XS. 100% Stock. Just had the refrigerant refilled. Like the title says, the A/C always starts out cold, but becomes hot after a few minutes. If I turn the A/C off for an extended period of time (hour or so?) it will come on cold again. It has been like this since I bought the car in May of 2012 and I never cared. I always put the windows down anyway, but my pregnant sweating wife is having NONE of that. Please help before she kills me! Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 23, 2013 Share Posted June 23, 2013 I think your system is low on refrigerant. Quote Link to comment Share on other sites More sharing options...
crazyman03 Posted June 23, 2013 Share Posted June 23, 2013 who refilled it? if you refilled it yourself, did you have the a/c going and the clutch was enabled before you ran the can? the gauge will read a false reading if you just put it on the fitting and open the can up without the clutch running. -Justin Quote Link to comment Share on other sites More sharing options...
ferret Posted June 24, 2013 Share Posted June 24, 2013 You may have a worn compressor clutch. Check out these threads: http://www.ultimatesubaru.org/forum/topic/98733-2003-legacy-h6-intermittent-ac-issue/ http://www.ultimatesubaru.org/forum/topic/119296-2003-outback-intermittent-ac-clutch-failure/?hl=zexel&do=findComment&comment=1006174 http://www.subaruforester.org/vbulletin/f88/ac-fine-till-its-hot-57077/ Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 24, 2013 Share Posted June 24, 2013 check the rad fan function too. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 24, 2013 Share Posted June 24, 2013 probably low and you probably have a leaky oring. $5 fix, very easy. you can buy the cheapie ghetto gauges for a few bucks at an autoparts store to measure the current pressure to see if it's low. if it's low then and was charged properly/working before then you simply need to replace the two orings on the compressor ($5 and 15 minutes): http://www.ultimatesubaru.org/forum/topic/127980-diy-ac-air-conditioning-leak-refrigerant-repair-for-5-or-less15-m/ Quote Link to comment Share on other sites More sharing options...
jmoss5723 Posted June 27, 2013 Author Share Posted June 27, 2013 I had it filled at the dealership when I took it in for unrelated service. It blows Ice cold for 10 minutes, then gets hot. So I don't think it is low on refrigerant. If it were, it would just be warm all of the time. A bad clutch sounds like it could be the problem. Quote Link to comment Share on other sites More sharing options...
