O.C.D. Posted June 24, 2013 Share Posted June 24, 2013 I am in the process of rebuilding my trans and I cannot seem to get the 4WD pinion shaft gear off of the trans. There is a gear with a lock/castle not on the shaft and I cannot get it to budge. Can any of you please tell me how to get this off? Link to comment Share on other sites More sharing options...
talldude Posted June 27, 2013 Share Posted June 27, 2013 An impact wrench will back that nut right off. You might replace it with a new one (dealer item, I had to get one about 6 months ago, so they're still available) as the nut gets torn up when you peen it on installation. Everything should come apart once that nut is off. I had good luck reassembling with high torque permatex sealant (the gray stuff) with no gaskets. Link to comment Share on other sites More sharing options...
O.C.D. Posted June 27, 2013 Author Share Posted June 27, 2013 Thank you for the reply. So far the impact has not made it budge? I still have not been able to get it off. Link to comment Share on other sites More sharing options...
ivans imports Posted June 27, 2013 Share Posted June 27, 2013 Dremel tool with thin wheel cut down one side to relase it the get new nut Link to comment Share on other sites More sharing options...
talldude Posted June 28, 2013 Share Posted June 28, 2013 I suspect you need a bigger impact. or more PSI? My $30 Campell Hausfeld wouldn't have moved it either, even tho it was 1/2 inch drive- utterly useless. Harbor Freight has a pretty good one for under $100. It's a tool you will always need... Link to comment Share on other sites More sharing options...
O.C.D. Posted June 28, 2013 Author Share Posted June 28, 2013 On 6/27/2013 at 3:04 PM, ivans imports said: Dremel tool with thin wheel cut down one side to relase it the get new nut I hadn't thought of that!!! If I can get the Dremel in there you might have the answer. Already have the nut ready to be ordered. On 6/28/2013 at 4:04 AM, talldude said: I suspect you need a bigger impact. or more PSI? My $30 Campell Hausfeld wouldn't have moved it either, even tho it was 1/2 inch drive- utterly useless. Harbor Freight has a pretty good one for under $100. It's a tool you will always need... You know I am not sure what this Craftsman puts out. Maybe I should just bump her up to 120 PSI and have at it. I only tried at 90 cause I don't want to snap a ring or pinion tooth. Thank you guys! Link to comment Share on other sites More sharing options...
ivans imports Posted June 28, 2013 Share Posted June 28, 2013 Got tierd of fighting stuck subaru bolts / nut bought me a 3/4 snapon gun 1250 ft lbs this whould take it off Link to comment Share on other sites More sharing options...
talldude Posted July 2, 2013 Share Posted July 2, 2013 The nut will break loose waaay before any damage is done. Besides, think what a transmission has to go through every day! Link to comment Share on other sites More sharing options...
O.C.D. Posted July 2, 2013 Author Share Posted July 2, 2013 Ironically I have not attempted to remove it again cause of free time. I think my approach will be full psi on the impact and if that doesn't work I will Dremel the nut. As it has been removed before you would think it easy to remove. We shall see. Thanks to everyone for the responses. Link to comment Share on other sites More sharing options...
Singularity21 Posted July 3, 2013 Share Posted July 3, 2013 Where, perchance, did you obtain the blown up schematic for the transmission? My fourth gear is gone and I have another transmission that I can make them one. Good luck, and keep posting, I'm quite interested. Link to comment Share on other sites More sharing options...
O.C.D. Posted July 3, 2013 Author Share Posted July 3, 2013 On 7/3/2013 at 4:26 AM, Singularity21 said: Where, perchance, did you obtain the blown up schematic for the transmission? My fourth gear is gone and I have another transmission that I can make them one. Good luck, and keep posting, I'm quite interested. I was graciously given a copy of the parts catalog. Been VERY helpful to say the least. Link to comment Share on other sites More sharing options...
ivans imports Posted July 3, 2013 Share Posted July 3, 2013 I have at least 4 of those trannys all good just sitting around have no cars for them 1 Link to comment Share on other sites More sharing options...
O.C.D. Posted July 5, 2013 Author Share Posted July 5, 2013 Well Ivan, I had to resort to the Dremel technique,.....and it worked!!! Link to comment Share on other sites More sharing options...
ivans imports Posted July 5, 2013 Share Posted July 5, 2013 And folks we lay this nut down to sleep ! Link to comment Share on other sites More sharing options...
O.C.D. Posted July 5, 2013 Author Share Posted July 5, 2013 On 7/5/2013 at 2:47 PM, ivans imports said: And folks we lay this nut down to sleep ! LOL. Damn thing was a brute! Link to comment Share on other sites More sharing options...
