dmplatt Posted April 19, 2004 Share Posted April 19, 2004 Anyone out there have a used power antenna assembly (or functioning mast) that they care to sell? For a 1999 Legacy Sedan. Link to comment Share on other sites More sharing options...
Gene J Posted April 19, 2004 Share Posted April 19, 2004 dmplatt said: Anyone out there have a used power antenna assembly (or functioning mast) that they care to sell? For a 1999 Legacy Sedan.Are you sure you need the whole antenna? The antenna itself is easy to replace if it has broken off. If the motor is fine it is a piece of cake! (My wife likes to listen to the radio in the car wash!) Link to comment Share on other sites More sharing options...
dmplatt Posted April 19, 2004 Author Share Posted April 19, 2004 I think the motor is ok... mast has been bent for MANY weeks so everytime it powers up/down there is a few clicks at each end (stripping the gears maybe). One way or another the clicking has to go. Carwash huh? Try this dance: 1. Lift bike off roof rack 2. lower wheel over antenna mast tangling mast with spokes 3. bend mast to 45 degree angle 4. curse loudly Link to comment Share on other sites More sharing options...
Gene J Posted April 19, 2004 Share Posted April 19, 2004 Odds are good you need only replace the mast. Unscrew the cover. (It's a little chrome piece) Turn the radio on and off until the mast comes out. It's OK to help it. When it comes out you will see that the bottom of the mast is just a plastic track. It's really clever the way it works. I'll bet you will see the stripped spots! It is a common replacement part. To replace it push the new mast in. Turn the radio on and off a few times until it goes all the way down. Replace the cover. It's easy. Take the old one out and take it to the dealer. The masts for the wagon and sedan are different and do not interchange. The dealer gave me one for the sedan as he didn't think I looked like a wagon sort of guy! I couldn't figure out why it didn't work until I put them side by side. Link to comment Share on other sites More sharing options...
tcspeer Posted April 20, 2004 Share Posted April 20, 2004 Raise it to top and then unplug the elc. connector to the power antenna. It will stay up and no more noise. Link to comment Share on other sites More sharing options...
dmplatt Posted April 20, 2004 Author Share Posted April 20, 2004 Brilliant, and since I never wash it no worries in the carwash!! Link to comment Share on other sites More sharing options...
charlierh2 Posted April 20, 2004 Share Posted April 20, 2004 how much would it be for the new antena? 97 legacy sedan if you know thanx Link to comment Share on other sites More sharing options...
dmplatt Posted April 20, 2004 Author Share Posted April 20, 2004 New from the dealer: 181 for the whole assembly (motor and mast), 55 for mast only Link to comment Share on other sites More sharing options...
tcspeer Posted April 20, 2004 Share Posted April 20, 2004 Car washes have been around long before antennas started going up and down. And if it knocks its off you are still no worse than you are now, needing an antenna. mine has been unpluged for around five years and I have washed it in automatic car washs. Link to comment Share on other sites More sharing options...
charlierh2 Posted April 20, 2004 Share Posted April 20, 2004 thanx very much. and i assume that includes the new track? Link to comment Share on other sites More sharing options...
drquasievil Posted April 20, 2004 Share Posted April 20, 2004 Make sure you buy OEM mast. I bought another brand and had to return it. Link to comment Share on other sites More sharing options...
1997outback Posted April 16, 2007 Share Posted April 16, 2007 drquasievil said: Make sure you buy OEM mast. I bought another brand and had to return it. i unscrewed the top part to my power antenna, can i replaCE it with just a mast? Link to comment Share on other sites More sharing options...
CamoMan Posted April 19, 2007 Share Posted April 19, 2007 1997outback said: i unscrewed the top part to my power antenna, can i replaCE it with just a mast? Get SIRIUS and forget about it. I use the FM tuner on my receiver in my 99OBS and always got static in the same places everyday on the way home. Found out if i just push my antenna all the way in (my antenna isnt power, it slides in and out by the windsheild), I get perfectly clear signal everywhere!! oh... except at the carwash, overhead structures block the incomming signal Bababooeeee!! Link to comment Share on other sites More sharing options...
