one eye Posted June 26, 2013 Share Posted June 26, 2013 Does anyone know if the stock EA71 fuel pump is strong enough to pump to an EA81? Im having a fuel Delv. issue and not sure what would be causing it, Also does anyone have pics on how the EA81 D/R lever was set up I just need a few Ideas https://www.facebook.com/photo.php?fbid=10201384505602471&set=a.2479154666086.2144705.1469125085&type=1&theater¬if_t=photo_comment That's the new project , not sure it worked (the link) Jeff Link to comment Share on other sites More sharing options...
ivans imports Posted June 26, 2013 Share Posted June 26, 2013 My 81 brat is old body with ea81 high low factory trans is a bitt dif were shifter gos and has high low on dash and tach. I made it spi thiss made it run way better. The ea81 uses a retuing sestem the ea71 dose not i think you can put the spigot from ea71 carb to ea81 carb thiss may help alos try boling back thru lines into tank mine had s--t in the lines or sock at the tank and was just barly geting feul thru Link to comment Share on other sites More sharing options...
ivans imports Posted June 26, 2013 Share Posted June 26, 2013 Sorry blowing thru Link to comment Share on other sites More sharing options...
one eye Posted June 27, 2013 Author Share Posted June 27, 2013 fuel is pumping out not sure if its enough pressure though.............................. Jeff Link to comment Share on other sites More sharing options...
Subruise Posted June 27, 2013 Share Posted June 27, 2013 that thing had a bees nest in the fuel door when i got it :/ Link to comment Share on other sites More sharing options...
ivans imports Posted June 27, 2013 Share Posted June 27, 2013 I i had a $ for every mud wasp nest that caused me grief in every spigot hose hole you name it preshure is erelavent flow is what matters on the ea81 they had a fillter on the neddle seat that realy liked to plug up and is only acsess from inside carb have had many problems with this screen pluging Link to comment Share on other sites More sharing options...
