elchicharo2000g20 Posted June 28, 2013 Share Posted June 28, 2013 hello every one I have a problem whit 06 Tribeca is runnin hot on idle I replace the radiator because is cloge on one side but still I replace the wather pump still the same thermostat still I due block test and no problem I by pass the oil cooler the heater and the same I don't no whats the next thanks Link to comment Share on other sites More sharing options...
coolskaterkid Posted June 28, 2013 Share Posted June 28, 2013 Are the electric fans working? If it has electric fans? Link to comment Share on other sites More sharing options...
elchicharo2000g20 Posted June 28, 2013 Author Share Posted June 28, 2013 Hi yes working perfect start between 214 and 220 the problem is they don't stop for the same Link to comment Share on other sites More sharing options...
coolskaterkid Posted June 28, 2013 Share Posted June 28, 2013 So the fans will just keep running and it keeps heating up? But it doesn't heat up going down the road? Sounds like an air flow or water flow problem to me. Thermostat should be changed also, use Subaru brand. Maybe you have air in the system from when water pump and radiator changed. Was the system burped to get air out. Link to comment Share on other sites More sharing options...
elchicharo2000g20 Posted June 28, 2013 Author Share Posted June 28, 2013 yes when the car is on the road no problem, I change the thermostat I bleed the system like they said, even I put the car whit the front up I try vacuum the system and the same I think I have water flow problem because I put the coolant flush machine and no problem the fan work and stop normal Link to comment Share on other sites More sharing options...
Prwa101 Posted June 28, 2013 Share Posted June 28, 2013 What kind of thrumastat? A Subaru one? Or cheap knock off from parts store? Oem stant #48457 Subaru's are very specific when it comes to thrumastats. Link to comment Share on other sites More sharing options...
