Brake Job Mystery 2009 Forester
So I have two left over small rubber tubes after doing the front brakes. They are about 1 inch long and 1/8 inch hole.  Its not the caliper pin sleeves, but I am thinking it might be part of the lower pin. That pin has an indention and thought maybe it fell off when taking them in out.
 Any ideas? I just found it laying on the floor after I finished, never saw it come off.
Thanks!
Yes until now (40 k miles) It did not gave any problems. Probably when I will replace my brake pads and discs next time I will order a refurbish kit and try them again but that will be at least an other 60k away. Until then I drive it like it is now.
What I do at every interval (7.5k) is taking the brake pads off the car, and check if they can move freely, additionally I clean and regrease the slide pins too (slidepin grease from european brake vendor) and apply copper paste on the brake pads and guide plates.
