yutanaro Posted July 1, 2013 Share Posted July 1, 2013 I have a 2003 Subaru Outback and I needed to repair the rear outer seatbelt due to a tear in the webbing. I purchased a new seat belt assembly from Subaru to replace it. When trying to install it I found that I could not get the seat belt to extend from the retractor no matter what I tried. It is brand new and I noticed when I took the broken belt off, it locked up as well so I don't think it has a broken retractor mechanism. I attempted pulling slow, fast, hard, soft, up, down, left and right with no success. Feel like an idiot. Anyone have any ideas? Thanks a lot! Link to comment Share on other sites More sharing options...
lmdew Posted July 2, 2013 Share Posted July 2, 2013 You seat belts should be covered under warranty unless the retract was faulty. Many of the belts have to be in the proper position to release. Link to comment Share on other sites More sharing options...
nipper Posted July 2, 2013 Share Posted July 2, 2013 Lifetime warrenty on the seatbelts. Go to a dealer Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 2, 2013 Share Posted July 2, 2013 It's very tricky to hold the seatbelt mechanism in the proper orientation to prevent the latch from engaging. It will work just fine once installed in the car. Link to comment Share on other sites More sharing options...
idosubaru Posted July 2, 2013 Share Posted July 2, 2013 On 7/2/2013 at 7:14 AM, Fairtax4me said: It's very tricky to hold the seatbelt mechanism in the proper orientation to prevent the latch from engaging. It will work just fine once installed in the car. +1 and also to what was said earlier- seatbelts are lifetime replacement so the dealer will do it if the car hasn't been wrecked, worked on, modified, etc. Link to comment Share on other sites More sharing options...
Rooster2 Posted July 2, 2013 Share Posted July 2, 2013 A few years back, I tried unsuccessfully to install belts into a friend's 2002 OBW. His dog had gone nuts and chewed the back seat belts into a mess. Try as I might, I couldn't figure out how to install the belts. He said the dealer wanted $800 to fix the belts. He finally had the dealer do the work. It must be labor intensive to replace the belts at $800. We never knew about the belts being a lifetime warranty item............but maybe not so for dog damage. Link to comment Share on other sites More sharing options...
yutanaro Posted July 2, 2013 Author Share Posted July 2, 2013 On 7/2/2013 at 1:49 PM, Rooster2 said: A few years back, I tried unsuccessfully to install belts into a friend's 2002 OBW. His dog had gone nuts and chewed the back seat belts into a mess. Try as I might, I couldn't figure out how to install the belts. He said the dealer wanted $800 to fix the belts. He finally had the dealer do the work. It must be labor intensive to replace the belts at $800. We never knew about the belts being a lifetime warranty item............but maybe not so for dog damage. I had pretty much the same problem. I had heard about the lifetime warranty but I had assumed I wasn't covered. The belt didn't break on its own, it got damaged. Does Subaru's warranty cover damage by the owner? Thanks for the input everyone. Link to comment Share on other sites More sharing options...
