88RX Posted July 3, 2013 Share Posted July 3, 2013 Just wondering if anyone else is crazy enough to play with these engines. I know Z31 injectors work and are bigger but are there any others? Engine managemwnt is virtually non existent other than mega squirt right? Quote Link to comment Share on other sites More sharing options...
-tombba- Posted July 4, 2013 Share Posted July 4, 2013 You can basicly use any stand alone ECU system in EA82 engines. Jsut have to make sure it can do both fuel and ignition at the same time. Search function helps to find some info about the ijectors. There isn't many options to use but there still is some options available. I just got one of my injector sets out from a cleaning and they measured around 260cc@3bar so I don't know if the euro engine injectors are bigger than the USDM engine ones. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted July 4, 2013 Share Posted July 4, 2013 have used toyota and nissan injectors before must have same ohms Quote Link to comment Share on other sites More sharing options...
rpholz Posted July 4, 2013 Share Posted July 4, 2013 I've got a haltech running my RX. I won't comment on megasquirt. Evo8 injectors fit as well, but unless you plan on running all the boost there are a bit overkill. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted July 5, 2013 Share Posted July 5, 2013 Just use a rising rate adjustable fuel pressure regulator. Old Subarus run a low fuel pressure (36psi IIRC) where the industry standard for non-direct injection is like 43psi or something. By raising the fuel pressure your 185cc/min injectors will act more like 250cc or there abouts. 1 Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted July 5, 2013 Share Posted July 5, 2013 (edited) Just use a rising rate adjustable fuel pressure regulator. Old Subarus run a low fuel pressure (36psi IIRC) where the industry standard for non-direct injection is like 43psi or something. By raising the fuel pressure your 185cc/min injectors will act more like 250cc or there abouts. The same trick works on the SPFI injectors as well. Edited July 5, 2013 by Crazyeights Quote Link to comment Share on other sites More sharing options...
AKghandi Posted July 5, 2013 Share Posted July 5, 2013 (edited) I remember looking into this and 83 nissan 280zx turbo injectors are the same, now what flow they are rated at is unknown to me but I'm sure that information is on one of the nissan forums Edit: stock 83 turbo 280zx injectors are around 260cc. http://www.oreillyauto.com/site/c/detail/BWD0/27536/02521.oap?year=1983&make=Nissan&model=280ZX&vi=1209406&ck=Search_02521_1209406_3158&pt=02521&ppt=C0024 also, 87 to 92 supra turbo injectors are 440cc, but would require some work to fit Edited July 5, 2013 by AKghandi Quote Link to comment Share on other sites More sharing options...
djellum Posted July 6, 2013 Share Posted July 6, 2013 ive heard of people using thunderbird injectors as well. there are a couple styles and as long as you get the right style the will "fit", though application does change them a bit here and there. there was a place in Washington (Tacoma I think) that will rebuild your injectors and rerate them to whatever you want them to be. used to cost about $30 per injector plus shipping, but that was years ago. might be worth some google time. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted July 9, 2013 Share Posted July 9, 2013 ive heard of people using thunderbird injectors as well. there are a couple styles and as long as you get the right style the will "fit", though application does change them a bit here and there. there was a place in Washington (Tacoma I think) that will rebuild your injectors and rerate them to whatever you want them to be. used to cost about $30 per injector plus shipping, but that was years ago. might be worth some google time. Might that place be Witchhunter? Quote Link to comment Share on other sites More sharing options...
TOsborn Posted July 9, 2013 Share Posted July 9, 2013 ive heard of people using thunderbird injectors as well. there are a couple styles and as long as you get the right style the will "fit", though application does change them a bit here and there. there was a place in Washington (Tacoma I think) that will rebuild your injectors and rerate them to whatever you want them to be. used to cost about $30 per injector plus shipping, but that was years ago. might be worth some google time. I think your speaking of "Dr Injector." Great shop, I buy all my injectors through them. Very knowledgeable and helpful about anything fuel injector related. Quote Link to comment Share on other sites More sharing options...
djellum Posted July 10, 2013 Share Posted July 10, 2013 Might that place be Witchhunter? really couldnt tell you, I just remember it was between me and Seattle. Sounds like Tosborn has a name to check out, id start there. Quote Link to comment Share on other sites More sharing options...
