yobhgareb Posted July 4, 2013 Share Posted July 4, 2013 Hi guys. Im putting an ej20 in my 1986 l series, and would like to build the front ej20 casing onto my ea82 transmission. Has anyone got any pics of this procedure, or know of a good writeup? Thanks Link to comment Share on other sites More sharing options...
rxleone Posted July 4, 2013 Share Posted July 4, 2013 Check out the EA 2 EJ swap - it's a stickied thread at the top of this forum. I don't think you can swap bellhousings, but you can buy or make an adaptor plate to go between the EA transmission and the EJ engine. Link to comment Share on other sites More sharing options...
Gloyale Posted July 4, 2013 Share Posted July 4, 2013 (edited) Dual range or single range? You need the matching case type to make this work. If your L series box is single range, and the EJ20 box is as well then it's as easy as swapping out the guts and reassembling......nothing else required. D/R will reuire both D/R boxes....And may require modification to the ring gear to clear the larger 1:59 reduction low range gears (it's actually the shifting collar that hits the ring gear.......more a problem with the 4.11 gearset. not sure what your EJ20 box is. Although I'm assuming you want to keep the 4wd not AWD so the EJ gearset will not be used. Edited July 4, 2013 by Gloyale Link to comment Share on other sites More sharing options...
yobhgareb Posted July 4, 2013 Author Share Posted July 4, 2013 (edited) Dual range or single range? You need the matching case type to make this work. If your L series box is single range, and the EJ20 box is as well then it's as easy as swapping out the guts and reassembling......nothing else required. D/R will reuire both D/R boxes....And may require modification to the ring gear to clear the larger 1:59 reduction low range gears (it's actually the shifting collar that hits the ring gear.......more a problem with the 4.11 gearset. not sure what your EJ20 box is. Although I'm assuming you want to keep the 4wd not AWD so the EJ gearset will not be used. My l series is the 4wd with hi and lo range. I haven't bought a donor ej20 box yet. {The donor legacy I have is an auto} I can get a 99 impreza dr box worth the money. Is it a big deal to modify the ring gear? I just want to keep all the functions of my l series gearbox, but just use the ej20 casing? Edited July 4, 2013 by yobhgareb Link to comment Share on other sites More sharing options...
Gloyale Posted July 4, 2013 Share Posted July 4, 2013 My l series is the 4wd with hi and lo range. I haven't bought a donor ej20 box yet. {The donor legacy I have is an auto} I can get a 99 impreza dr box worth the money. Is it a big deal to modify the ring gear? I just want to keep all the functions of my l series gearbox, but just use the ej20 casing? Get the 99 impreza D/R box. Swap the EA82 diff, Shafts, and possibly the D/R shift fork and gear shifter forks, although they may be the same. Now that I think about it more, you will not need to modify ring gear or collar.....just use all the EA stuff toghether should be fine. I had issues trying to fit 4.11 AWD gearset in combo with the 1:59 L hi/lo upper shaft. We didn't get any EJ D/R's here in the US Link to comment Share on other sites More sharing options...
yobhgareb Posted July 5, 2013 Author Share Posted July 5, 2013 Get the 99 impreza D/R box. Swap the EA82 diff, Shafts, and possibly the D/R shift fork and gear shifter forks, although they may be the same. Now that I think about it more, you will not need to modify ring gear or collar.....just use all the EA stuff toghether should be fine. I had issues trying to fit 4.11 AWD gearset in combo with the 1:59 L hi/lo upper shaft. We didn't get any EJ D/R's here in the US Thanks for the advice. Link to comment Share on other sites More sharing options...
ivans imports Posted July 5, 2013 Share Posted July 5, 2013 I have biult a cupple i use the 2wd legacy case with ea82 pushbutton guts in it works well should be same as what you want to do but dobut you could use the wrx awd and internals in it 1 Link to comment Share on other sites More sharing options...
erondondon Posted September 22, 2013 Share Posted September 22, 2013 (edited) ea82+ej20 gibrid http://www.subaru-faq.ru/forum/index.php?PAGE_NAME=message&FID=12&TID=38036&PAGEN_1=27 Edited September 22, 2013 by erondondon 1 Link to comment Share on other sites More sharing options...
ivans imports Posted September 22, 2013 Share Posted September 22, 2013 awd not 4x4 must have been a rx trans Link to comment Share on other sites More sharing options...
erondondon Posted September 22, 2013 Share Posted September 22, 2013 (edited) FT+difflock+dual range 1.44 what else do you need? I have enough body ej + ea (rx turbo) transfer no viscous Edited September 22, 2013 by erondondon Link to comment Share on other sites More sharing options...
