ivans imports Posted July 6, 2013 Share Posted July 6, 2013 Working on a 95 svx having a problem to read engine codes anyone have a printout of code read procedure on svx ? has a airbag light on two if anyone knows how to code check airbags whould help to thanks all Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 7, 2013 Share Posted July 7, 2013 If its OBD1 it Should be the same as reading codes on any other OBD1 Subaru. If its OBD2 and the scanner won't connect check ground connection for the diag plug under the dash. Link to comment Share on other sites More sharing options...
ivans imports Posted July 8, 2013 Author Share Posted July 8, 2013 odb1 and has no green conector just multi conector with small jumper pins is a odd car 96 but no obd2 nowere to plug in scaner. Cant figure out how to get codes Link to comment Share on other sites More sharing options...
NorthWet Posted July 8, 2013 Share Posted July 8, 2013 I can't find my FSM-on-Disk, but here are a couple useful links for SVX tech stuff: The Subaru SVX World Network > How-to Docs & FAQs http://www.alcyone.org.uk/ssm/ I hope that this helps. Link to comment Share on other sites More sharing options...
ivans imports Posted July 9, 2013 Author Share Posted July 9, 2013 thank you North wet helped tons now i feel confedent to diagnose this car 1 Link to comment Share on other sites More sharing options...
