84 gl Exhaust Studs
buy an M10 x 1.25 bolt and cut it to length?  chase the threads with a die or if it's clean enough and you have some small enough files you can work it that way.
auto parts stores have M10 x 1.25 exhaust studs, would they not work?
the auto parts stores i went to that have a large selection will have M10 x 1.25 exhaust studs, they unfortunately have a "band" in the middle, the threads aren't continuous..which has always seemed odd.  but anyway, it's not mid-way, one side has more threads than the other and it'll only fit "one way" into EA82, ER27, and EJ heads, but they work.
use those, or cut those to work as well?
