1-3-2-4 Posted July 12, 2013 Share Posted July 12, 2013 I was just wondering I swore I saw something where they were listed in inch pounds but I'm seeing here 7.2 & 14.5 FT.lbs maybe I used a inch pound wrench.. Do you guys use a beam or clicker for this area? I ended up before using a inch pound wrench since my lowest only goes to 10. Link to comment Share on other sites More sharing options...
davebugs Posted July 12, 2013 Share Posted July 12, 2013 I've used both. CLickers I don't think are that accurate at such low ratings. And it was after I had snapped 2 bolts not realizing there were 2 different torque settings. IIR one for the 4 beefier bolts and one for the 2 closest the cam seal. On the plus side I did get me a spiffy new set of small EZouts! Still sucked! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 12, 2013 Author Share Posted July 12, 2013 I've used both. CLickers I don't think are that accurate at such low ratings. And it was after I had snapped 2 bolts not realizing there were 2 different torque settings. IIR one for the 4 beefier bolts and one for the 2 closest the cam seal. On the plus side I did get me a spiffy new set of small EZouts! Still sucked! seems like I would be better off with the inch pound wrench again.. (it walked off) it's a 20-200 in.lb range suck having to buy another but oh well.. Link to comment Share on other sites More sharing options...
davebugs Posted July 12, 2013 Share Posted July 12, 2013 I downloaded the FSM from a link from a member and I had notes in the garage on the head bolt torque sequence and lbs and cam cap specs.. I haven't done one recently enough to remember what they are. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 12, 2013 Author Share Posted July 12, 2013 Link to comment Share on other sites More sharing options...
