michaelsobrien Posted July 12, 2013 Share Posted July 12, 2013 (edited) First post. Bit of a crisis here as I'm stuck at the in-laws. Any help would be appreciated. I can operate the shifter as long as I use the shift lock release (with the screwdriver), otherwise I can't shift it out of park. My brake lights are fine. Is it possible this is just a blown fuse and something I can fix myself? Edited July 14, 2013 by Legacy777 Link to comment Share on other sites More sharing options...
Legacy777 Posted July 14, 2013 Share Posted July 14, 2013 Welcome to the USMB. The shift lock solenoid is controlled by the shift lock controller by a swtich coming from the brake pedal. it's possible the solenoid, the controller, or the switch may be bad. My suggestion would be to just continue using the screwdriver until you get home and can have a shop look at it. You won't hurt anything by using the screwdriver to get it out of park. Link to comment Share on other sites More sharing options...
