Miami Hatch
subyxx
  • 3 months later...
Dats a niiiiice!!! Great hatch man, and those wheels are cock!
Lowering the back CAN be easy... start soaking with PB now! You just need to take the flat plate off the trailing arms and move it up a couple splines on the torsion bar. Just be sure to mark it first, so you know where you started. If you cant get the plate to come off the outer end of the torsion bar, you can pull out the bar with it and reclock it on the inside, it's splined on both ends. It's much harder to gauge where you move it to that way, but if you have the car jacked up evenly, you should be able to measure off the ground. May have to try a few times to get it where you like.
  • Like 1
  • 4 weeks later...
