idosubaru Posted July 22, 2013 Share Posted July 22, 2013 (edited) A Phase II EJ22 equipped 99 Legacy - will it have a speed sensor (the one on the front diff) like the 95-98's or later models? finally found it on opposed forces - it's not listed under the transmission section, it's obscure... looks like they're the same from 95-2004, even 4 and 6 cylinders, i thought they'd be different with Phase II at least. part number 85082AC002 http://www.ebay.com/...R-/231003855716 Edited July 22, 2013 by grossgary Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 22, 2013 Share Posted July 22, 2013 Yes they are the same. Or at least, they all work the same way. The older sensors were larger and are a tight fit on 99 and newer trans, but still usable. The new sensors are slightly smaller, but work the same way. All they do is create pulses as the sensor turns. 8 pulses per revolution of the sensor. Link to comment Share on other sites More sharing options...
