jonas Posted July 26, 2013 Share Posted July 26, 2013 (edited) Installed those Hellas as seen in the "What have you done" thread and everything worked great! It's been 2 weeks and the Hellas still work great. Now when I go to turn on my headlights on the dim setting I get a faint flicker of the hi-beam indicator light and my hi-beams are on very faintly. When I switch on the hi-beams, one goes out completely, one low beam goes dim, and the remaining are normal. Any ideas? Edited July 27, 2013 by jonas Link to comment Share on other sites More sharing options...
Mykeys Toy Posted July 26, 2013 Share Posted July 26, 2013 Re-check your wiring to the hella's. Your ground is on the wrong pin if it is an H4 conversion. If not make sure it is a 4656 bulb and not one of the many other versions that fit the 4x6 buckets. I think the is a diagram on the danielstern website. Link to comment Share on other sites More sharing options...
jonas Posted July 26, 2013 Author Share Posted July 26, 2013 will do, thanks. Link to comment Share on other sites More sharing options...
jonas Posted July 26, 2013 Author Share Posted July 26, 2013 unhooked the hellas, no change. would a screwy headlight be an issue? Link to comment Share on other sites More sharing options...
jonas Posted July 26, 2013 Author Share Posted July 26, 2013 Oh, and thank you Mod! Link to comment Share on other sites More sharing options...
jonas Posted July 26, 2013 Author Share Posted July 26, 2013 I do know a faulty alt. can do some weird stuff. Link to comment Share on other sites More sharing options...
naru Posted July 26, 2013 Share Posted July 26, 2013 Bad ground Link to comment Share on other sites More sharing options...
jonas Posted July 26, 2013 Author Share Posted July 26, 2013 Bad ground Hmm, gives me an idea. When looking down from the front of the car the left wire on the hi-beam headlight connector looks a little booged up. If that's a ground wire........... Link to comment Share on other sites More sharing options...
jonas Posted July 26, 2013 Author Share Posted July 26, 2013 nope, not it. Link to comment Share on other sites More sharing options...
jonas Posted July 27, 2013 Author Share Posted July 27, 2013 Not a clue..... Link to comment Share on other sites More sharing options...
jonas Posted July 27, 2013 Author Share Posted July 27, 2013 It's just the headlights and hi-beam indicator, everything else works fine. I did have some headlight switch problems before that I fixed. That's all I can think of... Link to comment Share on other sites More sharing options...
turbosubarubrat Posted July 27, 2013 Share Posted July 27, 2013 is anything tapped into the same wires as the head lights are on? a power source for the headlights and some other stuff on my 83 wagon was tapped into by a radio some one installed which was making the headlights really dim to where you couldn't tell they where on then when you turned on the brights the relay went off. Link to comment Share on other sites More sharing options...
jonas Posted July 27, 2013 Author Share Posted July 27, 2013 (edited) Nope, been just fine till now, with the exception of the light switch which I fixed. The issue with the switch was the male/female connector into the harness fried so I just removed the connector and directly wired it up and it was working fine. Now I wonder if there was an issue with the actual switch. Here are some pics. http--,,--// That is on low beams. The left one is dimmer than the right and the brights are on but very faintly. Edited July 27, 2013 by jonas Link to comment Share on other sites More sharing options...
jonas Posted July 27, 2013 Author Share Posted July 27, 2013 http--,,--// This is hi-beams. The left hi-beam is on but very faintly and the left low gets dimmer. Link to comment Share on other sites More sharing options...
jonas Posted July 27, 2013 Author Share Posted July 27, 2013 pulled inst. cluster for a peek. everything looks good. has to be the switch. ill replace that and see what happens. Link to comment Share on other sites More sharing options...
jonas Posted July 29, 2013 Author Share Posted July 29, 2013 checked all the grounds I could find still nuttin. Link to comment Share on other sites More sharing options...
Meeky Moose Posted July 29, 2013 Share Posted July 29, 2013 look under the dash, just behind the fuse box, there is a big yellow plug, could be orangeish too.. it is the main plug that runs the lights and some other stuff, i've seen them burn the pins inside the connector, pull it apart and check them.. Link to comment Share on other sites More sharing options...
jonas Posted July 29, 2013 Author Share Posted July 29, 2013 I know the one you're talking about. Looks fine on a visual but i'll actually pull it apart. Gonna put a replacement light switch in but i don't hold out much hope for that. Link to comment Share on other sites More sharing options...
ruparts Posted July 29, 2013 Share Posted July 29, 2013 (edited) I know the one you're talking about. Looks fine on a visual but i'll actually pull it apart. Gonna put a replacement light switch in but i don't hold out much hope for that. Hi, we went through a similar problem like this in another thread not long ago. in the same area , behind the fuse panel look for the main wiring harness coming in/up from the floor/firewall,, looking for a large (12ga i think) Black wire , several inches long which sprouts off from the main harness , originally has a brass ring connector on it.. this is a very important ground wire !! my car had very similar and other weird light issues till i found this and grounded it to the body .. the thread was from july 9th 2013 " wont start " started by member godsmulligan , i made replies there too, read through the thread and there are pics ,, the ground is in his last pic , and might be this is your issue ,, i know it was what was wrong with my wagon light problems, and has been great ever since i fixed that wire. Edited July 29, 2013 by ruparts Link to comment Share on other sites More sharing options...
jonas Posted July 29, 2013 Author Share Posted July 29, 2013 Thanks Ru, i did check that wire, It is grounded firmly. Stuck my hand back there and gave it a good tug and it didn't budge. I've pretty much resigned myself to having to take it to a shop. I haven't done anything except remove headlights to repaint front and installed off road lights, and those are powered from the battery with their own relay. I have spent hours going over every inch under the hood and behind the dash. Lost..... Link to comment Share on other sites More sharing options...
jono Posted July 29, 2013 Share Posted July 29, 2013 I just know you have to be careful with the lights you fit. I also have a quad light beast that had really good low beam until I found it was all four all the time. The inner high beam inserts had a structure at the back for replaceable H4 bulbs that earthed from one pin to the body via the metal base the bulb sat in and the spring retainer - drove me nuts the night before presenting for roadworthy inspection , swapped switch and all sorts of checking. I ended up insulating the spring retainer with heat shrink then installed quartz sealed beam high beam units that just had the pins set in the glass - insulating things. I have also learnt that to add a relay to lights and horns on these old Subarus to not only just tap into the positive for the relay but to use the same original earth/ground/neg- side of the original wiring circuit to avoid problems. I also found a low 1.4V coming from the high beam circuit when just on low beam in an EA82 L series when I hooked up driving lights like yours. I ended up putting two basic diodes in line (series) in the relays trigger wire from the high meam circuit to reduce the Volts to a non trigger Voltage , ntil I actually had high beam on. Diodes are said to absorb 0.7V, I found I needed to to get it down about 0.5V. Very sensitive relay trigger. Some also use diode protected relays to prevent any feedback, diode inside them. Loks like your headlight is having its earth or power sapped by something... Link to comment Share on other sites More sharing options...
jonas Posted August 2, 2013 Author Share Posted August 2, 2013 Anyone know where the headlight relays are located? Link to comment Share on other sites More sharing options...
Mykeys Toy Posted August 2, 2013 Share Posted August 2, 2013 It should be the round thing above and behind the fuse box. Link to comment Share on other sites More sharing options...
jonas Posted August 3, 2013 Author Share Posted August 3, 2013 cool, i'll check it out. Link to comment Share on other sites More sharing options...
jonas Posted August 3, 2013 Author Share Posted August 3, 2013 Would a faulty headlight cause something like this? When I unplug the pass. side low beam both low and hi beams go out on pass side but driver side is unaffected. When I repeat it on the drivers side the hi and low beam lights only go out if I unplug each one individually, pass side unaffected. Oh, and the only round thing behind the fuse box is the wiper relay. I think the headlight relays are the 2 round silver ones just to the right of the fuse box. They are fine. I'm getting a new headlight switch so I hope that's it. Link to comment Share on other sites More sharing options...
