MR_Loyale Posted July 27, 2013 Share Posted July 27, 2013 My driver side auto seatbelt (93 Loyale Sedan) has been erratic lately sometimes working sometimes not. Usualy a kick to the driver side panel got it working. Now it doesn't move at all. I cannot find a wiring diagram for them and am not sure what connector or wire it is. Rather than tearing it apart to trace it out, I was wondering if someone had a wiring diagram or could tell me the wires to trace. 1 Link to comment Share on other sites More sharing options...
nick1208 Posted July 27, 2013 Share Posted July 27, 2013 Same thing is happening to my passenger side, i have to ask the passenger to close and open the door again and it usually works the 2nd time. I would love how to fix this before they stop all together. bump Link to comment Share on other sites More sharing options...
MR_Loyale Posted July 27, 2013 Author Share Posted July 27, 2013 (edited) I found the problem. I had to take out the hood release cable bracket in order to find the other connector. It is a three wire inline connector one side has pink wires, the other blue wires. I connected them and it works. I suspect the connector was originally loose and it finally came apart. It was behind the kick panel on the driver side. Not sure if that is the same thing on the passenger side, but it might be worth a look. Edited July 27, 2013 by MR_Loyale Link to comment Share on other sites More sharing options...
MR_Loyale Posted July 27, 2013 Author Share Posted July 27, 2013 (edited) On 7/27/2013 at 10:45 AM, nick1208 said: Same thing is happening to my passenger side, i have to ask the passenger to close and open the door again and it usually works the 2nd time. I would love how to fix this before they stop all together. bump Are you going to the Subaru meet in Bremerton tomorrow? If so I can meet up with you and help you with it. http://www.bignorthwest.com/ Edited July 27, 2013 by MR_Loyale Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted July 29, 2013 Share Posted July 29, 2013 I forget if the parts are compatable... but if they are, consider swapping in normal manual belts from a GL... problem solved. (maybe tear one apart at a u-pull it so you can see if all the proper bolt holes are still there) Link to comment Share on other sites More sharing options...
MR_Loyale Posted July 30, 2013 Author Share Posted July 30, 2013 Personally I like the auto seatbelts. They are novel. I can understand folks wanted to give up on them though if they don't like the hassle. In twenty years of use, this is the first time they acted up. Not bad in my book. Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted August 1, 2013 Share Posted August 1, 2013 I had the same problem when I first got my 91 sedan, the drivers side was possessed to where it would start, go half way, then go back, then all the way open. I found it was a loose connector by the kick panel just below the hood release cable and the carpet was falling down.. I cleaned and dielectric greased up the connectors, tucked them back in behind the panel and no phantoms since then! under the pass seat, there are a few relays and IIRC, one is for that auto seat belt motor which is at the bottom of the B pillar kick panel, right above the rocker.. 1 Link to comment Share on other sites More sharing options...
TomRhere Posted August 2, 2013 Share Posted August 2, 2013 Faulty door switch(s) or the wiring can cause issues also. On Wagons, the control unit is behind the left trim panel in the cargo area, to the rear of the wheel well. Link to comment Share on other sites More sharing options...
NorthWet Posted August 2, 2013 Share Posted August 2, 2013 Just to add info for future searchers, the XT's unit is on the right side just in front of the right-rear wheel arch, under the interior panel. For anyone that has a dead controller, the Legacy controllers will (functionally) fit if you use (cut and splice) the Legacy power connector on to the EA82 wiring harness, and adapt the mounting. Link to comment Share on other sites More sharing options...
marku71 Posted February 17, 2014 Share Posted February 17, 2014 New to the forum - and have 1992 Loyale 4 WD wagon and auto seat belts also started to be erratic similar to above post - except that they act and appear to be erratic in unison (not just one side and similar movement). Saw above regarding sedans on one side or another and about wagons from Tom. For the heck of it I quickly peeled carpet back near driver kick panel and cleaned up a pink connector (only 2 wire) but not fix and was not looks. QUESTION - So per Tom's post on the Loyale wagon they actually put the control unit in the far rear cargo area panel? Seems like a long way from the motor assemblies for the shoulder belts which from Chilton manual appear to be in the forward kick area - or did I misread above? Turns out I also have weird look to door switch so even though it works dome light fine I cannot rule that out. I also appear to have a battery drain when it sits. I guess gremlins like this pop up in 20+ yr old car. (but hate to ditch a 4 WD that runs so good other than oil leaks I am guessing form valve covers becoming an issue). Link to comment Share on other sites More sharing options...
Gloyale Posted February 18, 2014 Share Posted February 18, 2014 Electric motors are in the B-pillar...not the kick panel. Control unit is on drivers side behind the plastic panel in the cargo area/quarter panel side. Ussually the problem with these is the "buckled" and "limit" switches. One of each in the buckle and another limit switch in the front part of the track. Subaru on;y published a diagarahm in the 88 FSM. Link to comment Share on other sites More sharing options...
