high pitched whine 2003 outback
Hi
I have a 2003 outback wagon, auto, 2.5 with about 140,000
miles on it.  A couple of days ago I
noticed a high pitched whine that seems to be coming from the front.  It only occurs when the car is moving forward
at a very slow speed, like crawling around in a parking lot.  The whine does not change if the car moves a
little faster  but goes away completely
at normal driving speeds say 10 mph and up.
The noise does not occur when going slowly in reverse.  Any ideas would be much appreciated.
thanks in advance
Pinion would get louder with speed and the sound would become higher pitched the faster you went.
Could be the power steering pump, a belt tensioner pulley, a number of things.
Does it vary with engine rev?
Ever make the noise while stationary?
While coasting in N?
It could be the noise doesn't go away as you speed up, but becomes masked by other noises.
