RWD 87 RX
DangerDussault
wellllll its pretty easy but dont expect it to last long  these trans are not meant to be rwd.
take one of the front axles out, then take it apart, take the stub shaft and put it back in the hub. then lock the center diff. bingo rwd.
if you want to make it last longer you'll need a better rear diff and a better transmission.
I circled the stub shaft, the res of the axle can be removed.
