Stereo Wiring, '93 Loyale Canadian Model
Mustakrakesh
I wasn't sure it this is the right place to post this,
But I need some help, Every wiring diagram, or chart I've looked at doesn't seem to match up with my stock radio.
Memory (+12v Constant) Red/Green
Ignition (+12v Switched) Blue/Yellow
Ground (-) Black
Illumination
Dimmer
Power Antenna Red/White
Left Front Speaker (+) Yellow
Left Front Speaker (-) Blue/Red
Right Front Speaker (+) White
Right Front Speaker (-) Blue/Black
Left Rear Speaker (+) Yellow/White
Left Rear Speaker (-) Blue/Red
Right Rear Speaker (+) White/Blue
Right Rear Speaker (-) Blue/Black
Some of my wires match up, but most don't
I have
Blue (With a 5A fuse inline)
Black
Red
Red/Green
Yellow/Red
Yellow
Green
White
Yellow/White
Grey
Yellow/Black
Orange (with connector end)
Anyone have any ideas? My stock radio model # is 86225GA400
Edited by Mustakrakesh
Yes I'm trying to put in a new radio.
Shouldn't I just be able to solder to the right wires?
Thats how I usually do it...
I guess what I'm trying to say is that wiring diagrams and charts don't match up with my stock radio.
So I have no idea what wire does what.
Are you trying to install an aftermarket radio? If so, they sell adapter harnesses right on ebay.
Yes but the adapters splice right side and left side grounds tougher. Kills the deck.
Green wire by itself is constant power
Blue/yellow wire is switched power
White is front left positive
Yellow is front right positive
Run new wires to the front speaker grounds at the kick panels
Yellow white is rear left positive
Use the blue/red for rear left negative
White/blue is rear right posit e
Use the blue/black for rear right negative
Red and red/green wires are for illumination dimmer
Edited by Gloyale
I took the radio out last night and I was refering to the wire colors that go from the connector to the radio, because I was hoping to swap pins on my two connectors so I don't have to solder anything, but I just went out to the car and I have all the wire colors mentioned above. the color changes at the connector.
My bad!
I should be able to get this to work.
Where are the rear speakers located?
Is it possible my model only came with front speakers?
Also why new grounds? (My guess would be that after 20 years they're probably worn out)
My bad!
Factory wires combine front and rear grounds together. This setup doesn't work well for decks designed to run separate grounds. Running new grounds to the front speakers is one simple way of seperating the wiring.
Your loyale may not have rear speakers, but the wiring will be there for them.
If you want to stay with just front speakers, no need to seperating grounds just use the wires listed as rear grounds for the front ground.
My bad!
  • 1 month later...
I am using one of the ebay harnesses from Scoche (spelling) with no issues at all. They are a couple bucks. I wouldn't want to cut the factory wiring personally.
If you have rear speakers your deck will burn out from the combined grounds.
Interesting. I don't have rear speakers now, but I have in other Loyales hooked up the same way and never had an issue. But I did however run dedicated front speaker wires to the doors, instead of using the factory front speaker wires. Could this be why I didn't have issues?
Yeah, with no rear speakers you are all good.
OR.....
if you run dedicated wires to the fronts and run the the rear speakers through the harness you are be fine.
  • Like 1
