fastest/cheapest way to gain ground clearance
i MIGHT be getting a 82 brat, and if i do, what is the quickest, and cheapest wany to gain a few inches of ground clearance without a lift, i cna fabricat almost anything, i just dont have the time nor money for a lift and i just got some 6lug 15's with off road tires for free, they are 27's i think.
Thanks,
Shean
Tires are the fastest way to get ground clearance, and if you have tires and rims that is also the cheapest.
Gearing is something you may want to think about when balancing your needs/requirements for the Subie?
I have 26's and I notice the difference in my gearing:-\
Good luck,
Glenn
82 SubaruHummer
01 Forester
Actually - it's faster and cheaper to build a lift than it is the beat the hell out of the fenders and go at it with a sawzall. All you need is 10 blocks for the front made from 3.5" square tube, two bits of 3x2 angle iron for the rear EA82 coil-overs, and then the front stut tops, which is just some C channel, and a couple pieces of flat steel. Takes about 1/2 day to install, and the cost is about $50 for the materials, and another $15 for the bolts and hardware. Oh - and a bit of 1/2" ID tubing for the steering extension - about 3" of it. You just cut the steering shaft, and weld the tubing in-between the two peices. Seriously, lifts are not that hard to build.
ok then how about i buy everything needed for a 4inch lift, and pay you $50 to help me build/install the lift? sound good??
i would do it my self, but a lack of welder and experance hinders me, or i would have john do a mudrat lift, but very low on funds now.
I'm definitely interested in this too. I have the welder and tools. I want put a 2 or 3 inch lift on my 87 wagon. If the procedure is the same for an EA82 wagon I sure would love to see some pics of the fabricated parts and the installation so I could do it.
For those wondering about block placement and whot not, here is a handy little pic. it shows the main blocks, and how to lay out the supports (HIGHLY reccomended for anything over 4"s). Basically your bolting in a block where ever there is a bolt going into the body between the subframes and the body.
*note, in the pic, there are two block missing, the inners on the radius rod plates. Also this is for EA81 vehicles, I haven't drawn up an EA82 yet. Sorry.
Heheh, would help if there was a link.
http://usmb.net/gallery/assorted/lift
